Go Back   Automotive Forums Car Chat > Land Rover > Discovery | LR3 | LR4
Old 03-31-2010, 07:30 PM
Landrover1980 Landrover1980 is offline
Help with my 04 land rover Disco
Hello i recently bought a 2004 land rover discovery with 54k miles. i noticed that the tank said use supreme gasoline. i put 87 octane in it the first day i had it . Well it started making a knocking sound and i just started using the most expensive gas because someone told me thats what u have to use in landrover. It sounds like the knocking is coming from under the hood. has anyone else had this problem or know what this might be and how i can fix it . thanks
Old 03-31-2010, 08:45 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Help with my 04 land rover Disco
Lots of things can cause a knocking noise.
However, in this case, if there was no knocking noise until you put in the 87 octane gas, then the knock is caused by abnormal fuel combustion, called "knock" or "ping".
All engines will mix fuel and air in a 'fog'. Then this 'fog' is compressed and ignited. The more the fog is compressed, the more energy can be extracted from the fuel.
Normally, the fog will burn quickly after being ignited by the spark plug. However, if the fog is compressed too much, it will explode, sometimes before the fuel is ignited by the spark plug. This explosion is heard as a knock or ping sound. A bit of knock does no harm, but extended periods of knocking may damage an engine.
The expensive, supreme gasoline can tolerate more compression (before knocking) than regular gas. Your engine is probably compressing the fuel beyond the tolerances of the 87 octane. So fill up with the supreme and you should be fine.
BTW, your engine has a device called a 'knock sensor' that detects knock and adjusts the ignition system to somewhat compensate for poor quality gasoline. If you are hearing a lot of knocking, this sensor may not be working.
However, you should always use supreme gas in your Land Rover. It may cost more, but often some (but not all) cars get better fuel economy using supreme. For example, my '97 Cadillac gets 15% better fuel economy by using supreme, which more than offsets its higher price.
Old 12-26-2011, 06:47 PM
Affordable Engine Affordable Engine is offline
I have a company called AffordableEngine.com and we sell used engines including Discovery motors. I just posted an article outlining a conversation I had with an experienced Discovery engine rebuilder.
He said one of the keys to a long lasting Discovery engine was using premium fuel. The other tips were around oil filters, oil type and timing covers. Just for some insight, a rebuilt Discovery engine could be $5K to $6K if you can find one...
Thanks
