Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 03-31-2010, 06:46 PM
jhuy2001 jhuy2001 is offline
89 starting problems
ive seen many posts with the same probs, truck sometimes starts sometimes not. had this problem forever it seems. i just replaced the motor, starter, altenator is fairly new, good battery new connections. a common cause ive seen in the forums is faulty wiring between the ign switch and starter. a common solution ive seen is to bypass with a push button. if this sounds right how do i go about doing that?
Old 04-08-2010, 09:32 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 89 starting problems
The short version -
You need a good quality Normally Open pushbutton switch
One side of the switch connects to a switched +12V source (switched meaning you have to place the Ign Sw in the RUN position to get the +12V)
The other side of the switch connects to starter
For safety use an inline fuse on the +12v side of the switch
To start the engine, place the Ign Sw in the RUN position and push the button to start.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
