Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 03-31-2010, 10:04 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
01 Town Car OD Light flashes
01 Lincoln Town Car with a flashing OD light, i pulled the codes.
P1783- Trans Over Temp condition.
P0712- Trans Fluid temp Sensor Low Input.
Anyone know what could be causing these codes. Tranny fluid is a little dirty but full.
Put some Shutter Fix in about 2 years ago because of a problem with trans shuttering when going into overdrive. I seen alot of problems with the OD light flashing on the internet but no resolutions.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 03-31-2010, 01:44 PM
All2kool's Avatar
All2kool All2kool is offline
Re: 01 Town Car OD Light flashes
So you put something in the Transmission other than Transmission Fluid and now the light flashes - two years later?
Old 03-31-2010, 06:32 PM
Kitt1993's Avatar
Kitt1993 Kitt1993 is offline
Its hard to say, If I were you, I would flush the transmission and put Lucas in it. The shuddering problem you had a few years back is very common with theses cars. I don't believe the 2 are related. Also might be just a bad sensor or a short. I am not sure where the sensor is located though.
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Old 04-01-2010, 02:45 PM
I know the sensor is located under the oil pan. I was just checking to see if it was something common that someone on here had a FIX for.
