Old 03-30-2010, 09:27 PM
spinnertennis spinnertennis is offline
06 f-250 air conditioner problems
My 06 f250 will only blow air out of the defrost I have the digital screen and when i press the front vent button it shows to switch but it doesnt. Ican change the temp of the air though.
Old 03-31-2010, 09:49 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Re: 06 f-250 air conditioner problems
control head, or HCV is unplugged, little grey vacuum hose on pass side under the hood.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 04-01-2010, 09:05 AM
where is the control head because the HCV is connected.
Old 04-01-2010, 11:15 PM
Are you sure its connected in the right spot? Alot of people make the mistake of connecting it on the backside of the HCV, it should be on the front. If all is well your control head inside the cab is malfunctioning, Do you have the Dial style or the push button?
'95 Ford F-150
Ford Racing Pride
General Motors who?
Old 04-02-2010, 09:17 AM
I was looking at my electronic vaccum pump and it seems to be vibrating alot and its not pulling much vaccum do you think it could be that. I have the push button style ac control panel
Old 04-04-2010, 10:48 PM
Not likely, most of the time the vacuum pump either works or it dosent. if HCV is hooked up, and right, theres not much else besides control head that will cause it to blow on defrost only, maybe a sticking blend door, but ive not seen many problems with the blend doors in superdutys
'95 Ford F-150
Ford Racing Pride
General Motors who?
Old 04-05-2010, 08:41 AM
rjinmt rjinmt is offline
check under your dash for hose cracks,up here in montana whrn it gets below zero and you put your feet under the dash to get them warm again and you hit a hose they crack real easy
Old 04-09-2010, 02:02 PM
jpawl jpawl is offline
Vacuum leak or not hooked up right like fordtrucksonly said.
Usually when it's stuck in defrost mode like you said it is, that's the first thing I look for......
