Old 03-30-2010, 09:17 PM
HeWhoKillz HeWhoKillz is offline
89 cav. temp sensor
I understand there are two temperature sensors on a 89 cavalier. Its got the v6 in it. Can anyone tell me the location of where they are? I need to test them with a meter and see if they are functioning properly. When the car heats up it idles bad and soon dies. It only stays running if you give it gas and I don't think its the fuel regulator.
Old 04-02-2010, 02:44 PM
jdl jdl is offline
Re: 89 cav. temp sensor
Circle with D, should be the coolant temp sensor, usually in the thermostat housing. N4 & N5 for the dash, gage and lite, backside of engine.
Old 04-03-2010, 01:31 PM
Can a failing coolant sensor cause the engine to act up when it warms up?
Old 04-03-2010, 02:38 PM
jdl jdl is offline
I can't be sure that is your problem,but, yes, a faulty cts can cause problems.
