Old 03-30-2010, 12:29 AM
jaimysessanna jaimysessanna is offline
94 Stalling, Bucking, Poor Fuel Economy
Hello everyone!
I still have a 94 LeSabre with a lot of miles. For months the car has been running like garbage, and I'm finally determined to find the solution to my problem. The car will run rough, stall when you come to a stop, and the mileage is somewhere in the high teens.
I replaced the intake manifold gasket, as well as the fuel pump, and fuel filter. I have proper fuel pressure at prime and idle as well as the recommended range when the fuel pressure regulator is unhooked. Recently my father purchased the Actron scanner that will scan the very specific OBD 1.5 computer that this LeSabre has. We scanned it and it kept calling the MAP sensor.
I have looked and looked and researched and I have come up with the conclusion that the L27 didn't have a MAP sensor, the only ones that did were the Series 1 & 2 L67 and well as the L36.
I'm going to re-scan again to see if I missed anything. In the meantime however, does anyone have any ideas as to what could be happening?
Thanks!
2007 Ford Taurus SE
3.0 Vulcan, AX4N, B&M Supercooler, PEAK Green Coolant, Mach RCU, Polk Audio db571
100,450 Miles
25 MPG all day long
Old 03-30-2010, 08:46 AM
maxwedge maxwedge is offline
A990 racer
Re: 94 Stalling, Bucking, Poor Fuel Economy
The code? can also refer to the maf, more likely. Disconnect it and see what happens.
