Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 10-30-2001, 10:15 PM
le_the_thriller le_the_thriller is offline
Unhappy Steering wheel shakes
I drive a 1991 g20 automatic; (about 101000 miles) no modifications as of yet -runs great, but feels weak
Well, yesterday I'm driving on the highway at about 85 mph for a short bit and then begin to apply the breaks to come to a stop. As I'm applying the breaks, i noticed how the steering wheel started to shake up and down. This was very noticeable and I seriously doubt that this is normal.
Not long ago a mechanic at PepBoys told me that i might need to replace the motor mounts because hte car 'jumps' when you put it into gear, so i need to get that cleared up quick.
Can this in any way be related to faulty motor mount(s)?
thanks!
1991 g20 automatic
Old 10-30-2001, 10:37 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
if you get the shaky steering wheel at high speeds during normal driving, you need a tire balance or wheel alignment. it might be the tires arent gripping the road right, which is in need for a wheel alignment. it might be the mounts, do you hear creaking noises coming from your engine bay when you drive slowly or turning? that is signs of bad mounts.
1.6 - The Underdog
GA16DE-T Club!
Old 10-30-2001, 10:53 PM
No, I don't hear any creaking noises when driving slowly..just the power steering "wheeeze" when I turn sharply. When I was breaking at that speed though, the wheel wasn't vibrating..it was shaking almost violently up and down. Unlike when i put the car into reverse or standing still while in gear, the wheel vibrates quickly up and down (not sure if that's normal either)
1991 g20 automatic
Old 10-30-2001, 11:22 PM
P10DET's Avatar
P10DET P10DET is offline
Re: Steering wheel shakes
Originally posted by le_the_thriller
I Well, yesterday I'm driving on the highway at about 85 mph for a short bit and then begin to apply the breaks to come to a stop. As I'm applying the breaks, i noticed how the steering wheel started to shake up and down. This was very noticeable and I seriously doubt that this is normal.
Warped rotors.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 10-30-2001, 11:42 PM
jmgladden's Avatar
jmgladden jmgladden is offline
Send a message via AIM to jmgladden
Warped rotors.
I second that. Had the same problem with my Acura Legend a few years ago. Bought some replacement Brembo rotors and it went away.
Buy new rotors, don't let someone talk you into getting them machined. It is a waste and you have the same problem again in no time. Of course you'll need to change the pads at the same time also.
The wheels shaking at high speeds is wheel balance. Bad alignment will cause a pull, bad balance will cause shaking. I have the same problem now, probably because of the shitty factory tires on the car. Don't want to buy new ones cause I'm gonna order my wheels in a few weeks.
Good luck.
`Jonathan Gladden
1999 Infiniti G20
300M steering wheel shaking and pulling right?. sandrav0312 300M 1 08-07-2010 04:47 PM
steering wheel shaking, pulling to the right uspres2020 Escort 6 10-10-2009 05:58 PM
Steering wheel shakes after new struts Oopey Camry/Camry Hybrid/Vista 2 08-03-2009 01:00 PM
Steering Wheel Repair JDatx512 Tacoma 0 03-30-2009 12:55 PM
Problem with the steering wheel Ennar Aveo 5 03-03-2009 09:11 AM
