Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-29-2010, 08:34 PM
xXCivicXx xXCivicXx is offline
Post witch Prelude??
Witch year and type of Prelude should i get with witch engine in it???? and please explain why if possible thanks.
It is for a project but wanna leave the same engine that is in.
Old 04-11-2010, 07:45 PM
H23A1Lude H23A1Lude is offline
Send a message via AIM to H23A1Lude Send a message via Yahoo to H23A1Lude
Re: witch Prelude??
"Witch year and type of Prelude should i get with witch engine in it???? and please explain why if possible thanks.
It is for a project but wanna leave the same engine that is in"
Depends what kind of project you want to do. Both the 4th gen and the 5th gen Prelude's have stout motors, but like I said, it depends what kind of project you want to do. Cost is a factor too. Depending on how much you have will determine which motor you should get. The H22A1 is the 2.2 VTEC which I'm sure you already know. IF you have the money, you could build the block and the head and then boost it. Or you could get the H23A1 and boost that and build it. Main difference is the VTEC. Boosting a VTEC engine will require more money if you want to do it right because it's high compression already due to VTEC and if you boost it, even if it's on 8 PSi, you'll have some sick combustion going on in there. So you could boost the low comp H23 and have low end torque because of the bigger displacement and have the boost for the high end. Your call.
1994 Honda Prelude Si H23A1
Me: Get new U-Joints, then your Ford won't suck as bad.
Him: Do I need o-rings?
Me: No you idiot.
Him: Sorry, I've never replaced an O-Joint before
Me: FAIL
Old 08-22-2010, 09:10 PM
mperrett14 mperrett14 is offline
Re: witch Prelude??
i would go with a 1996 prelude vtech personally but hey thats just me.
