Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 03-29-2010, 08:14 PM
cheerish cheerish is offline
Unhappy ford focus idles rough
i have a 2003 ford focus with a 2.0 engine. it started to run real rough and my check engine light came on. they said it was my o2 sensor which i replaced along with the plugs and wires. neither seemed to help and keeps saying it is the o2 sensor. what should i do now?
thanks alot
Old 03-30-2010, 06:10 PM
Blaisemikau Blaisemikau is offline
Re: ford focus idles rough
Does it have a rattleing sound? or a smell of sulfer of a burning from time to time?
I have an 03 Focus svt and i had to get the catalytic converter replaced. Luckly it has its own 8 year - 80000 mile warrenty.
Did you take it do a Ford dealer for the light check?
OHHHH, when i first got mine...i had the same problem...they had my car for like a week and couldn't figure it out. I went to 2 different dealers. The second figured out that the wire/s coming from the O2 sensors had fallen on to the engine and were being shorted out!!!
Have them check that!
Old 03-30-2010, 07:22 PM
i found a hose that had a hole in it by using carb cleaner. u sray it on the hose and if your car revs up then you have found the hole. but it is a part that i have to order from the ford dealer... I do from time to time especially if i am running the heat that i can smell something burning. but when i turn the heat off it goes away...
