Old 03-29-2010, 04:48 PM
ImTyler ImTyler is offline
Subs cut off at high volume
Hello, My name is Tyler and I have a 1999 hyundai tiburon. Starting off with a normal walmart battery and a stock Altenator.
I can run the system and it sounds great. once i turn it up to 27 + it starts to cut off on the hards hits. only for a short pause to cut off again on the next hit. My ground wires seem to be fine. All the other wires are solderd very carefully.
Please help Me!!
I am running 0 gauge wire throughout the car leading from battery to cap to amp. the wires leading from cap to amp is only aprox. 4-6 inches long.
Im trying to run two Kicker 08S15L74 15" 2000w dual 4-ohm subwoofer wired parallel to 1-ohm. (in a sealed box if that matters.)
Specs:
  • Sensitivity: 89.4 dB
  • RMS Power Range: 1000 Watts
  • Peak Power Handling: 2000 Watts
  • Impedance: Dual 4 Ohm
  • Low Frequency response: 18 Hz
  • High Frequency response: 100Hz
Im using a Pyle PLCAPE50 5.0 farad digital power capacitor
My amp is a Hifonics BXI 2010D 2000w class d mono block brutus series amplifier
Specs:
  • RMS Power Range: 650-2000 watts
  • Number of channels: 1
  • Low Frequency Response: 35Hz
  • High Frequency Response: 250Hz
  • RMS Power Output: 1 x 650 W @ 4
  • RMS Power Output: 1 x 1300 W @ 2
  • RMS Power Output: 1 x 2000 W @ 1
  • Protection: DC, Speaker Short, Thermal, Overload
  • Power Supply MOSFET
  • Audio Output MOSFET
  • Dampening Factor: >250
  • Signal To Noise Ratio (A-weighted): >95dB
  • Variable Input Level Control (unbalanced): 0.2V - 9V
  • Input Level Control (balanced): 0.04V - 18V
  • Input Impedance (un-balanced): 47k-Ohm
  • Input Impedance (balanced): 20k-Ohm
  • Power / Diagnostic L.E.D.
  • Variable Low Pass Filter / 24dB: 35Hz - 250Hz
  • Variable Subsonic Filter / 24dB: 15Hz - 35Hz
  • Variable Bass EQ: 0dB - +10dB
  • Phase Shift (0 - +180 degrees)
  • Unbalanced Inputs (RCA)
  • Balanced Inputs (DIN)
  • Line Output (RCA)
  • Speaker Terminals (molded): 12ga
  • Power/Ground Terminals (molded): 0ga
  • Remote Bass Module: HFR-3
  • Parametric bass EQ with 45Hz bass boost and variable control from 0db to 10db
  • Variable Low Pass, Subsonic Filter, Phase Shift and Level Control
  • Balanced line input for MX accessories and line drivers
  • Bass Remote included
  • Built-In System Diagnostics protects from short circuits, over load, thermal overheat and DC Offset.
Old 03-29-2010, 04:58 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Subs cut off at high volume
turn the amp gains down .....
Old 03-29-2010, 07:55 PM
Gains all the way down, and the head unit is also bass 0 etc.
Old 03-29-2010, 09:14 PM
Audio Guy
take the cap out of the circuit and see what happens
also, what does the voltmeter read on the cap when it cuts out ?
Old 03-30-2010, 01:29 AM
Started out with no cap. Did this same thing before i added it. Figured the lack of a cap was the problemo. so i have tried testing it without the cap. no success
Old 03-30-2010, 01:31 AM
I have just played around a little with the car. It seems to last a bit longer when i drive for a while with no music or amp drawing power. maybe altenator charging the battery to peak be4 i play it? do you think the lack of a brand new batt. could be the problem?
Old 03-31-2010, 02:03 PM
Audio Guy
you're drawing too much power, batterr, alt or both may be going bad.
Old 04-05-2010, 08:56 PM
okay. so i bought a new battery more power better amp etc etc. but it still cuts out but only sometimes?
Old 04-06-2010, 06:33 AM
Audio Guy
your alternator is still not keeping up with the peak power demand.
Old 04-13-2010, 02:56 PM
IC? and damn! i cant find a better then stock altenator anywhere in this town!!!
Old 04-13-2010, 07:53 PM
Audio Guy
you have to order high output altys off the net, no one locally will carry them
Old 04-14-2010, 11:48 PM
okay. um what would your recommendations with altenators sizes be? i found a 90-amp remanufactured. would that be reasonable?
Old 04-15-2010, 07:41 PM
Audio Guy
that might be enough, you really need take current readings to see
Old 04-16-2010, 12:43 PM
think i just figured it out.. its shaking the head unit to much and it skips on the cds. Fm/am radio it doesnt cut out. i think problem solved. any recommended head units? that doesnt cost the price of my car. preferably with a remote. nothing fancy such as screens etc. or is there a simple fix to this problem?
Old 04-17-2010, 06:23 AM
Audio Guy
try cutting a tie-wrap or two into like 1/2 -1 " stips and stuffing them between the mounting basket and cd player. Also make sure the back strap is installed.
