gtp engine miss
hi everybody
i have a 97 grandprix gtp i've been having a problem lately ,when i push hard on the throttle the car miss , so i decide to replace ignition wires ,sparkplug (ac delco iridium)good thing is that a have a lot of spare parts for that engine so i replace ignition coil,ignition module ,pcm,injector,fuel pressure regulator, egr valve,and still the same so i decide the replace the fuel filter, the filter was almost plug ,put in the newin filter and still the same ,so after reading some post on this forum i realise that the fuel pump as two speed , and at the same time i also realise that the car miss when the supercharger kick in , so i replace the fuel pump relay but still the same i did try the fuel pump resistor bypass and the car is still the same ,the thing is the car run great when you drive normaly and start good ,and thinking maybe a electrical problem??? hope somebody can help me thank you Pierre |
Re: gtp engine miss
Welcome to AF.
You're probably in need of a fuel pump. The resistor bypass wouldn't affect hard acceleration, it is only used in low speed mode. I would get a fuel pressure guage and check fuel pressure before just arbitrarily replacing the pump, but with everything else you've already done, it's what I believe is your issue. Also, if you do find it's a fuel pump, there is an early and late model pump for your year, so make sure you get the correct unit.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Re: gtp engine miss
Have you had it scanned for DTC's. Let us know what DTC's come up. Does the SES light flash when the missfire occurs?
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Re: gtp engine miss
Did you replace all 3 coils? If your fuel pressure checks out, check the voltage going to the coils. See if any two have a lower output than the others. The ignitions is very prone to cause a miss.
Re: gtp engine miss
Re: gtp engine miss
hi guys
no my car doesnt have any modification ,i scan and there is no code ,i did not have a chance yet to do a pressure test ,like i said it miss a soon a see the light come on in the boost meter ,i release the gaz and it run good ,it look like the fuel pump since now then a know that there a high speed when the supercharger kick in ,i should be able to do a pressure test next week ,so i'll know ,if the pump is ok ,then the only thing a could think is the crank sensor , the reason is my rpm stop working a couple time in the last year (maybe 3 or 4 time ) if i'm not mistaking the rpm take the signal from the crank sensor but that i'm not sure one other thing when the car miss there is no check engine light so i dont think that is a misfire . i let you know
