Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-29-2010, 11:38 AM
orange_bullet orange_bullet is offline
Talking problem starting IROC need help
my 90 iroc z will only start if the steering collum is tillted all the way down and sometimes it wont even start like that. any suggestions. thanks
Old 03-31-2010, 11:00 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: problem starting IROC need help
Fairly confident the actuating rod from the column switch to the ignition switch is bent or the ignition switch is loose.
Old 06-05-2010, 11:46 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
I know this is a little old, you may have fixed it or not, but, could also be your VATS wire that runs to the ignition cylinder is broken, and every time you move the column, you make a connection to start. Does the security light come on when it doesn't start?
