Old 04-29-2003, 02:02 AM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
need quick timing help!!!!!
i need to know step by step how to set the timing on a 1993 accord lx (f22) we had to replace the head gasket, so the timing belt is off of the cam sprocket and everything, i just need to know how to put the belt back on and get the timing perfect, thanx in advance!!!
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 04-29-2003, 02:12 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
This is something I need to know as well since I have taken the head off my y8 and will need to put it back together soon...
Old 04-29-2003, 02:22 AM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
on the tcam gears, there are marks/notches, and arrows. you turn the gears so the arrow point straight up, and the notches should be parallel to each other on the inside of the two gears.....make sense?
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 04-29-2003, 02:54 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
dont forget to make sure the crank is at tdc too
Team Lonely Drivers
