Old 04-28-2003, 10:13 PM
doug294 doug294 is offline
Send a message via AIM to doug294
How much boost?
How much boost can my 91 Cvic HB SI hold? All I have is a mugen chip, intake, gutted cat/exhaust. What PSI could I run safely?
Old 04-28-2003, 10:19 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
well if you havent done anything with the internals. about 7-8 psi is your limit. any higher and you'll start breaking shit inside.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 04-28-2003, 10:24 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
what about in a zc? same thing?
Old 04-28-2003, 10:27 PM
yeah, the stock ZC rods can only handle ABOUT 200hp. So the psi would have to be relatively low to stay below the 200hp. you can do all you want to an engine, but if you dont upgrade your internals, the turbo will blow your engine up in no time. (unles you stay low boost 6-7-8 psi)
Old 04-28-2003, 10:28 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
yeah, i wouldn't go any higher than 9psi, and I'd only go that high if I was at the track. Street driving I'd go no higher than 7-8psi.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 04-29-2003, 07:48 AM
So to turn the boost up I have to upgrade my rods? I was told I just needed to get low compression pistons.
Old 04-29-2003, 01:45 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
With higher boost, you will need to upgrade your fuel system as well as ignition to prevent detonation, detonation is what kills turbo vehicles. Lower compression pistons will let you run higher amount boost safely and prevent detonation, stronger rods are required on high boost applications cause the stocks rods can only handle so much horsepower.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
