Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 03-28-2010, 06:59 PM
Paul Buxe's Avatar
Paul Buxe Paul Buxe is offline
Tilt nose ???
HAs anyone built a tilt nose for their Panoz? I love the car, but would like to be able to open the hood at the track with out finding some help and then not having the hood blow away or have someone step on it. So I was thinking about a tilt nose, the car already has an almost full nose to turn in to a forward tilt, so has anyone done this???
Paul Buxe
Panoz GTRO-0042 LS2 gone but not forgotten
Miata Chump Car
Mustang GT
Porsche Boxter (wife's ride)
Chev Suburban trailer hauler
Factory 5 Cobra Roadster, 392 stroker
You have to grow older, but you don't have to grow up
Old 03-29-2010, 02:17 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Re: Tilt nose ???
Yeah the hood setup is one of my dislikes.... takes two people and 10 latch points! We have the 4 original "buckle-type" (not sure what they're actually called), the 2 screws at the top rear, and we converted the 4 supports to hood-pins. It doesn't take long now that we're used to it, but it's not like a normal car at all. We bring a set of saw horses to set it on when at the track.
Our car is ABS plastic so the framework need4ed to make a tilt hood would be quite extensive and probably a bit on the heavy side.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 03-29-2010, 02:50 PM
NZGTRA17 NZGTRA17 is offline
Re: Tilt nose ???
Access from this could be OK.
Best reason I can think of for not doing this (other than cost / weight / complexity) is it would most likely be one piece and so in the event of an accident you would end up replacing a larger more expensive arrangement than the 4 panels that make up the nose and hood that we have.
If you were going to do this though, some real improvements could be made such as inner gaurds and venting the radiator air up through the hood to improve aeros and downforce.
Kel M
Panoz GTRA #17
New Zealand
Old 03-31-2010, 12:48 PM
Squerly's Avatar
Squerly Squerly is offline
Re: Tilt nose ???
I too would like to find a solution that would allow me access to the engine when I don't have help. Although some of you might see the extra weight as an issue, it wouldn't be for me. As for damage in a crash, that's something you would have to deal with on any car.
Squerly
Old 03-31-2010, 01:47 PM
Paul Buxe's Avatar
Re: Tilt nose ???
My hope is that I can just use the existing hood and fenders and hinge them at the front. I know this will require some brackets and stiffening supports, but I think it will be worth the trouble if it makes it easier to deal with at the track. I'll let you know if I am successful. And like anything else, if unsuccessful, I'll keep it to myself.
But first, I need to finish my LS2 engine conversion, its 75% complete and I need to get cracking. Track time is waiting.
Paul Buxe
Miata Chump Car
Mustang GT
Old 04-01-2010, 08:54 AM
Cobra4B's Avatar
Re: Tilt nose ???
Maybe you could visit a junk yard and get the oem hinges and latches from a C4 Corvette's clamshell hood.... just a thought.
Brian B.
Old 04-01-2010, 10:27 AM
Paul Buxe's Avatar
Re: Tilt nose ???
Good thought, my friend just did that for his Back Draft Cobra that he is building a tilt nose for. He found a BMW hoof hinge that looks like it will work.
Paul Buxe
Miata Chump Car
Mustang GT
Old 04-01-2010, 12:29 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
Re: Tilt nose ???
Make one of these - I did it with an electric winch, some good aluminum...
Make a tripod leg system that's collapsable, put in trailer and have it at the track.
You can also do a manual winch if you don't want to be resticted to electricity. like the picture.
Devin
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
