Old 03-28-2010, 05:04 PM
Goza Goza is offline
Just rebuilt the clutch master
The only place I could find it at was Advance. If you want to know, it was a VERY cramped up tight job, inside and out.
The only way I could get the line off the master was with a 10MM crow foot.The one I used was a MAC and looked like a line wrench anyway. Actually, that would be the only way I could see to do it. I could not get a straight line wrench on it and have enough room to turn it.
I did not use the original locking clip that was on the pin to connect the pedal to the master piston,but instead used a small cotter pin that did the job just as well.
A small pair of long needle nose pliers are almost a must.
