Old 04-28-2003, 02:46 PM
Deejay360's Avatar
Deejay360 Deejay360 is offline
Need Some Help
The car i painted was the porsche gt3 and I painted it yellow. The problem I have is that I sprayed the car shell and then I sprayed the wing and side mirrors and the wing and the side mirros dont match. The shell is darker then the wing and the side mirrors.
Wut should I do, I need some advice on how to match the wing and side mirros to the car.
Tom
Old 04-28-2003, 03:27 PM
Thor302's Avatar
Thor302 Thor302 is offline
does the body have more coats than the wing and mirrors? if so they just need as many coats as the body
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
this used to happen to me when i first started modeling. the reason being, i would use a darker color primer on one piece, and use a lighter color on another, then try spraying both with the smae color paint, and then one piece would be a darker shade, and the other a lighter shade, im supposing this is what you did, if so, i would say sand down or strip the pain and primer off the pieces that you dont like thw color, and make sure u use the same color primer on both
HTH
Rui
(modeling) = Click Here
Old 04-28-2003, 03:45 PM
Veyron's Avatar
Veyron Veyron is offline
Smile
All of Tamiya's yellow's will get darker the more coats or the thicker the the paint is. What I would do is put another coat on the parts that are lighter and repeat until they match the darker ones.
Old 04-28-2003, 04:09 PM
Verminator's Avatar
Verminator Verminator is offline
Send a message via AIM to Verminator
The only answer to this is to keep applying more coats to the lighter pieces, you will get a match eventually, the moral here is to assemble as much of the body as possible and do all your spraying at the same time to ensure consistency, good luck
Old 04-28-2003, 06:39 PM
Deejay360's Avatar
Thanks Guys for the help on how to fix my problem. This really helps Thank .
Tom
