Old 04-28-2003, 12:55 PM
rosman4u rosman4u is offline
88 dx to b16a swap, help??!
Hello all
I have an 88 civic DX, which so far i have got everything for the swap, here is my list of items:
b16a engine/tranny
88 Integra axles
ECU
Hasport Motor Mounts
Modified Shift Linkage
Now I am going to wire my dx harness and add more wires for the extra 2 injectors & to run the vtec soleniod. My question is do I have to use my map sensor or should I get one from a 95 del sol vtec even though I have the resistor box that came with the b16a? I've heard if i use my map sensor my engine will run rich. Also can I use the throttle cable from a 95 del sol DOHC vtec since mine will not work? (unless I modify it) Will my clutch cable work as well from the DX? If anyone can help me with this I will greatly appreciate it, or any sites for reference would work also.
Old 04-28-2003, 01:49 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: 88 dx to b16a swap, help??!
You can keep your stock map sensor as i did mine. I dont know about running rich. Never heard of that. If you want to change ur throttle cable then u need to get one from a 90-93 integra. The clutch cable will fit fine but u have to cut off the rubber piece a lil so u have more thread.
Old 04-28-2003, 06:32 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah i was wondering the same thing with my dx, because mellowboy, u got an si so u got a mpfi map senosr, but dx dpfis might make it run different
Team Lonely Drivers
Old 04-28-2003, 09:56 PM
mellowboy's Avatar
You can use the dx map sensor. When we put the zc in the dx we used the existing map sensor.
Old 04-29-2003, 10:55 AM
Well im gonna get a Air/Fuel guage and check my readings, I let you guys know the outcome.
