Old 03-28-2010, 11:43 AM
jghoseman jghoseman is offline
Help needed to remove old decals from backing paper.
Sorry if this has been covered before. I've tried searching but couldn't find anything.
I have an old decal sheet for a Senna helmet (1992).
They are from a Tamiya Tamtech Maclaren mp4/6, 1/14 scale.
When I soak them in water to remove them from the backing sheet they won't budge.
Tried hot water from kettle and also Micro Sol, still won't move.
Any suggestions thankfully received.
Old 03-28-2010, 03:12 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: Help needed to remove old decals from backing paper.
Is it even a water-slide decal?
Hiroaki Fukuda
Old 03-28-2010, 03:21 PM
It is, the decals for the body shell are vinal self adhesive, but you get a seperate sheet for the helmet which is water slide.
I have since tried heating them in the microwave in a shallow dish of water, still no joy.
Old 03-28-2010, 03:28 PM
stevetam stevetam is offline
maybe try adding soap to the solution - might act as a lubricant if it can get under the decal
Click on link for Softbank Multimedia Unlock Relock Rules
CLICK TO SEE TORONTO INTERNATIONAL AUTOSHOW PICTURES!
CLICK FOR MY
PHOTOGRAPHY GALLERIES
Old 03-28-2010, 03:47 PM
Thanks for the suggestion Steve, tried a few drops of washing up liquid in the water in the microwave and still no movement. Had them soaking for about 4 hours now.
Old 03-28-2010, 04:28 PM
hirofkd's Avatar
I see. Hmmm...
I have some old Tamiya decals that requires 5 minutes of soaking, but not like 4 hours.
It could be that the moisture in the air might have affected the adhesive that they permanently fixed the decals to the backing sheet. (That's just my wild guess...)
The only solution I can think of is to get a laser (or inkjet) printer decal sheet, and scan&print (or photocopy) the decals. You might have to use both white and clear types, depending on the design of each logo.
Hiroaki Fukuda
Old 03-28-2010, 04:33 PM
Unfortunatly, all the decals are now cut out and soaking, so any chance of copying them is gone.
Think I will have to start searching for a new set.
Trouble is the scale, 1/14, not exactly common.
Old 03-29-2010, 02:05 AM
Well, checked decals after leaving to soak overnight and guess what, still no movement
Old 03-29-2010, 09:37 PM
I've though up of a more intrusive way to get the decal out - an no guarantees the decal might even come off.
1. Cut a small slit at the edge of the decal
2. Use the edge of the modelling knife or even the tip of the pin and try to get under the decal.
alternately, the most extreme and dangerous method I could think of is to gently cut slit the backing in 2 but not severing the decal film. Fold the whole sheet where the slit is and hope you can peel the backing off the decal.
I wouldn't recommend doing any of these - as I have not bee forced to do any of these since my decals come right off a waterslide, but it seems like you don't really have a choice. You should probably test both ways on an area where there isn't a decal first.
CLICK FOR MY
Old 03-30-2010, 02:21 AM
I will give those methods a try, nothing to lose now.
Thanks.
