Old 03-28-2010, 08:38 AM
Firebird1 Firebird1 is offline
Send a message via AIM to Firebird1
Car won't start after siting for a short time
Don't know if anyone out there is havving this problem but after running to the store and parking the car and coming out about 30 mimutes later to and hour the car will turn over but will not fire or idle so low that it cuts off. then I wait a little while and try it again and get it to start but cut out again, then the next time try it and it has a rough idle put give it some gas and it start. Could this be the fuel pump? or do I need to replace the fuel filter? Help please.
Old 03-28-2010, 04:26 PM
robkiehl21 robkiehl21 is offline
Re: Cra won't start after siting for a short time
Idle air control valve
1992 Stealth RT/TT - 60K miles - K&N Intake w/ 4.5" adapter, Aluminium Y-pipe, Hallman Pro RX Boost Controller set @ 14.5psi, G-Reddy Blowoff Valve... Downpipe & cat removal coming.
1997 Pontiac Grand Prix GTP (daily driver) - ZZP 1.0 PCM, K&N Intake, custom exhaust, 3.35" S/C pulley.
Old 03-28-2010, 04:31 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
It doesnt sound like a IAC issue. If it were it would shut off at idle, but it would restart every time. Sounds like the whole "hot start" issue some people experience.
Old 03-28-2010, 06:37 PM
Igovert500's Avatar
blue + red light magnet
Re: Car won't start after siting for a short time
Sure y-pipe or something didn't pop loose?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-29-2010, 01:20 AM
No, not the Y-pipe connection or other pipe connection. Thinking about changing the fuel pump and fuel lines out. The car has a lot of miles on her. But thanks for the surguestion
Old 03-29-2010, 01:39 AM
Stealthee; what is the "Hot start issue" Explain please. Could this be a radiator problem. I have a 93 VR4.
Old 03-29-2010, 04:56 AM
Stealthee's Avatar
Its a fuel issue.
Old 03-31-2010, 03:07 PM
Igovert500's Avatar
After some reading, I think Stealthee nailed it. The general idea seems to be that since most gas stations now have ethanol added into their fuel, and ethanol has a lower boiling point than gasoline, after driving and then turning off the car, the ethanol is boiling in the fuel rails. It appears people are leaning towards thermal wrapping their fuel rails for more insulation to prevent this. Also hot-wiring the fuel pump, whether it's stock or not, guarentees full voltage to the pump at all times...which can only help. I didn't see a definitely conclusion as to if doing both completely solved the problem, but it looks the most promising.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-04-2010, 05:13 AM
Igovert500, thank you for the info I appreciate it very much and Stealthee; thank man for pointing the way I do appreciate it also. Would you think larger fuel rails would help this issue or adding a fuel additive to the fuel? Do you have any other suggestion?
Old 04-06-2010, 01:12 PM
Igovert500's Avatar
Nah, stick with the thermal wrapping, cheap and easy. Some of the people experiencing the issue have upgraded fuel rails/fuel pressure regulator, etc. Additives in general probably have a lower boiling point (ethanol additive being the source of the problem) so no I doubt they would help
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
