Old 04-27-2003, 03:50 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Rust on crank pulley and flywheel
On my D16y8 I've noticed that there seems to be some rust on my flywheel and the crank pulley... Should I be concerned about this? and if so, what is the solution? I'd rather not have to buy a new flywheel and crank pulley if possible...
Old 04-27-2003, 04:52 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
the flywheel you can (and should) take down to be turned. the rust is nothing. but the turning is something you should have done while the engine is out.
the crank pulley you can clean up with some WD-40 and if needed some steel wool
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 04-27-2003, 10:24 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
All of the crank pulleys that i have seen on a Honda all have some light surface rust on them, the flywheel is fine also.
