Old 04-27-2003, 12:23 AM
Goblin Goblin is offline
Unhappy Amp turns off!
every time i hook this shiz up the protection LED comes on and the amp turns off anyone know any reasons this would happen other then bad wires i checked all the connections...could it be ground wrong?
1991 Nissan 300zx TT
Upgraded Stillen Turbos
HKS Turbo Exhaust
Blow off valves
Old 04-27-2003, 08:33 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
3 things cause the protection circuit to kick in
1) overheating ... don't think that's the problem here
2) short in the power supply wires between 13V and GND ..... look at the wires VERY carefully, just one stray strand can cause this
3) (most likely cause) - you have your speakers hooked up for too low of an impedance for the amp to handle.
the only other option is that the amp is bad
Old 04-28-2003, 04:43 AM
checked into all but the second one listed and its not it.....so tommorow i tear out the wiring and start over
HKS Turbo Exhaust
Blow off valves
Old 04-28-2003, 04:25 PM
Audio Guy
try putting another amp in it's place first. might just be a bad amp.
Old 04-28-2003, 07:32 PM
i tried that and tried different Fuses...
its a 300watt amp and 2 350 watt 12"s with 8' wiring
HKS Turbo Exhaust
Blow off valves
Old 04-29-2003, 03:04 PM
i got it working....changed the ground to other side of car
HKS Turbo Exhaust
Blow off valves
Old 04-29-2003, 05:29 PM
Audio Guy
ahhhh .... the old "false ground"
Old 04-29-2003, 07:27 PM
redmanjd redmanjd is offline
also you never want your ground longer than 2 feet and the same gauge as your power
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 04-29-2003, 11:38 PM
well it was a full Rockford Fosgate Amp kit with less than a foot of ground.....same gauge as wire
HKS Turbo Exhaust
Blow off valves
Old 05-05-2003, 12:05 PM
Xo0phoenix0oX Xo0phoenix0oX is offline
Send a message via AIM to Xo0phoenix0oX Send a message via Yahoo to Xo0phoenix0oX
shorter ground is better
The greatest trick the devil ever pulled was convincing the world that he doesn't exsist...
