Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-28-2010, 05:48 AM
beaconhi beaconhi is offline
Ri inspection
A garage checked my "ON check engine light". They replaced the EGR and EGR solenoid. These parts are side by side on a 2001 Toyota Camry. They said they also cleaned the injectors,intake manifold, and fuel lines. $600 dollars later and two days the light came back on. The auto zone said the light was reading EGR again. When the same garage went to slap a sticker on the car for inspection they said a different code showed of P0401...any thoughts what next to check? Thank you
Old 03-28-2010, 11:45 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Ri inspection
Did Autozone give you the actual code or simply tell you they thought the problem was EGR related?
Mike
Old 03-28-2010, 02:38 PM
Re: Ri inspection
Mike
Mike
I believe the Zone said it was "egr flow insufficient"
Thanks for your help...
Old 03-28-2010, 06:57 PM
AF -Advisor
Re: Ri inspection
This the code description for P0401;
http://www.obd-codes.com/p0401
They are in the right area. I would go back and ask why the 2 items they replaced didn't solve the issue and did they really need to be replaced. My best guess at this stage is the EGR tube is clogged with carbon.
Good luck.
Mike
