Old 04-26-2003, 05:41 PM
SiRWannabe SiRWannabe is offline
Unhappy some ZC troubles
here my predicament
the zc is in, all hooked up, wired up but it won't start. I'm using a Si ECU, which had already been replaced with an 89 integra. The engine turns over with no codes but doesn't start. if you pour fuel into the intake it fires right up. The injectors have power but they don't spit fuel. its a dx-zc swap. been over the wiring many times. what could it be...please help cause if I don't get my car back soon I'm gonna look like this
Old 04-26-2003, 06:00 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
u must have wired it wrong, cause if hte injectors have power, then they just must not be firing, maybe your resistor box is no good
Team Lonely Drivers
Old 04-27-2003, 02:31 AM
the resistor box seems to work cause the guy tested it..the injectors are wired right..wired into A1 A3 A5 and A7 so I dunno whats up..maybe the injectors are clogged and dirty
Old 04-28-2003, 03:25 AM
ev0lution7 ev0lution7 is offline
Send a message via ICQ to ev0lution7 Send a message via AIM to ev0lution7 Send a message via Yahoo to ev0lution7
check the fuel filter pull the fuel lines and have somone put the key to the "II" then have them crank it see if its getting fuel that would be the FIRST thing i would do
Crxce- theoretically if u laid a starter on a table and hooked up the wires would it run???
BLU CIVIC- no...it doesn't have any legs
