Old 04-26-2003, 06:59 AM
Forhod's Avatar
Forhod Forhod is offline
Unhappy What to do with this?
Greetings to all.
Just wondering what will you do when you get this! :
This one hit me badly at the lower body.
Though I have sanded and I'll try painting the body again tomorrow..
Still, I would like to hear how you people solve this~
Thanks in advance!
Old 04-26-2003, 07:09 AM
christofurr's Avatar
christofurr christofurr is offline
I've had something similar to that before, and the conclusion I came to was I needed to spray for half a second away from the model before spraying the model, just to clear the nozzel out. Mind you, what I had wasn't as bad as that, so I'm not really too sure .
Old 04-26-2003, 07:29 AM
simdel1's Avatar
simdel1 simdel1 is offline
i would also sugest that you make sure that the body is clean and free of grease. it might help...maybe
Simon
Old 04-26-2003, 08:07 AM
srlxy srlxy is offline
can't really tell from the pics but you could try some wet sanding, then compound it...
Old 04-26-2003, 08:18 AM
njh njh is offline
I'm had a little problem like yours before. What I do is to sand those blops of paint away then respray it.
One problem I say might be because you sprayed too close to it.
Another might be you sprayed too thick at that area.
Old 04-26-2003, 09:25 AM
1204's Avatar
1204 1204 is offline
Proud AF Supporter
i will use normal masking tape to "stick" some paint away...
then respray that area again...
http://www.geocities.com/hobby1204/
Current Project:
Old 04-26-2003, 09:31 AM
Chain's Avatar
Chain Chain is offline
Youch!
That car's arse is suffering from chicken pox
Sorry Forhod, me no expert but if it was mine, I'll probably try to slice away those lumps if the paint already harden and sandpaper it down too to lvl.
To each his own!
Read the FAQ you faqer
Evo Meet....coming to a forum near you!
Completed!-Click on Pic:
Projects done and posted:
Subaru WRC2001 RGB-My first project in AF Click Here
In stocks:
Ferrari F1 2001
Tyrrell P34
CLK Warsteiner
Ford Performance Blue
Ferrari Enzo
Opel Team Holzer
Williams FW24
Old 04-26-2003, 09:49 AM
RallyRaider's Avatar
Zomby Woof
Did those blobs come out of a rattlecan?
If so I think you'd better start by tossing it and geting a new one!
Have alook in the FAQ, PMan has a manifesto on rattlecans, including preparation, that might avoid such carnage in the future.
Agree with the others - wait till the paint has fully cured, then sand and have another go.
Old 04-26-2003, 11:50 AM
Forhod's Avatar
Thanks for the reply to all!!
Well.. I personally feel that white is one of the colour which is hard to work with. Oh yeah.. I use Tamiya Spray Can
Guess I have to brush up on my spraying skills!~
And I read Pman's FAQ on spraying, put I skip the part where you leave a day to dry after " bathing " the car.
Now, the body is sanded down and I'll start trying again when the sun rises..
Once again, thanks all~
Old 04-26-2003, 11:51 AM
[S]ky|ine's Avatar
[S]ky|ine [S]ky|ine is offline
Send a message via AIM to [S]ky|ine Send a message via Yahoo to [S]ky|ine
Hmm.. Maybe isit you did not shake well for your spray can??? Or the paint is finishing??? If i were you, i will sand it away and respray it again
Good luck for your S2000
Old 04-26-2003, 11:55 AM
daggerlee's Avatar
Are those paint bubbles? Then you probably sprayed too thick too fast!
Dan
Old 04-26-2003, 12:26 PM
Forhod's Avatar
Yes, I think you got a bingo...
I press the nozzle down all the way and moving fast.. :x
[S]ky|ine : Well, I heat the can and shake it before I use..
Old 04-26-2003, 12:30 PM
Mean_B16's Avatar
Mean_B16 Mean_B16 is offline
This :thumbup: will save you a lot of future headaches! This is probably what caused it along with a few other posibilities, practice practice, practice!!!! that will be you best solution.
Old 04-26-2003, 01:29 PM
supratuner's Avatar
yea, also, just wash the model off before you spray, that will save you a lot of head aches, wash your hands too before you spray,
Rtuned's Avatar
Rtuned Rtuned is offline
is paint bubble. Spray too thick and cause the air bubble on the kit. It only happen on Tamiya can spray. So next time, spray thin layer by layer.:smoker2:
