Old 03-28-2010, 01:28 AM
countach79's Avatar
countach79 countach79 is offline
how to make a colour lighter
I have a metallic blue paint in a jar that i would like to be a bit lighter shade
would it be best to mix in some white or silver?
i would guess silver as the blue is metallic, but i just want to confirm it
and would i use the colour coat over a white primer or a silver base?
cheers
Jason
Old 03-28-2010, 05:31 AM
stevenoble's Avatar
Re: how to make a colour lighter
I would use silver to lighten it. Depending on how dark the blue is I normally use grey primer under blue. But if it's a very pale blue then go with white.
Steve Noble
Old 03-28-2010, 11:32 AM
MidMazar's Avatar
MidMazar MidMazar is offline
You can't really tell what will work for you. Id go with white, but light silver is a good choice also. Do remember if using white, youll have less flakes and with adding silver youll have more flakes.
If i was you i would mix a small batch of both and you decide.
In Progress
Old 03-28-2010, 10:21 PM
CrateCruncher's Avatar
CrateCruncher CrateCruncher is offline
I mix small amounts on a piece of white card or better yet, card shot with my primer. Making custom colors is a black art. I have tried to develop a sense of predicting results but find myself stirring drops together and getting unexpected colors all the time. Once I have the ratio's I like I scale it up to the volume of paint I need. (I think adding white will nudge your color toward "sky blue metallic" but could be wrong.)
Old 03-29-2010, 04:51 AM
Entau's Avatar
Entau Entau is offline
the best way to find out is to try it, usually i will try both on a small amout and airbush it on a plastic spoon and compare
Old 03-30-2010, 03:45 AM
countach79's Avatar
thanks guys
