Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-27-2010, 09:54 PM
OldMan9 OldMan9 is offline
Question Re: Unstable rpm idle same issue unsolve
I just installed a new iacv (idle air control valve) onto my car and the problem is still the same...............i did do all the air, fuel hoses cleaning and even put a bottle of (sea foam) fuel injector cleaner to clean injectors and fuel lines but the problem doesn't to go away............
Old 03-27-2010, 11:01 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Maybe a vacuum leak from intake manifold or somewhere else. Does your car is loosing power?
It's worst if your turn on A/C or release engine clutch a little bit when you're on 1st gear?
Does it run fine on 1st gear or it makes an abnormal engine noise when you accelerate?
Do you have visible fume at exhaust?
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 04-01-2010, 09:43 PM
Originally Posted by serge_saati View Post
maybe a vacuum leak from intake manifold or somewhere else. Does your car is loosing power?
It's worst if your turn on a/c or release engine clutch a little bit when you're on 1st gear?
no, there's no power lost and the first gear is driving fine. I've changed tps, fast idle thermal valve, first top piece of intake gasket, cleans injectors and still has the rpm idle unstable..........i lose so much of money/times buying this parts and that parts just thought it was the issues.
Old 04-01-2010, 09:45 PM
p.s,
i've noticed that my fast idle thermal valve has this rattling noise when i took it off and clean. When i shook it to left n right; the rattling noises is louder...........is that could be the one that causing my idle to jumped up n down???????
Old 04-01-2010, 10:14 PM
I don't a lot about fast idle thermal valve, but I think that it was the cause. But the problem had reappear, so maybe it's something else.
If you press the gas to idle at 1100rpm or more, does it still unstable?
Need to press gas to start engine?
