Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-27-2010, 04:11 PM
lipany lipany is offline
Shifting Problem. Please Help Out
Hi
Need some help please. Have a Ford Contour 98, with AT. Something is going on with it, because i can only drive it in reverse (R) or when i shift it to gear 1, it will go but very slow, with applying higher RPM. Just quit on me 2 days ago. Shifting from neutral (N) to drive (D) or to gear 2, does nothing to it. I think there could be several things wrong with it, but i don't get it. It quits working in the middle of drivnig.
So, My question is, What should I get into first to fix my car ?
Thank You !!
Old 03-28-2010, 10:25 PM
Davescort97 Davescort97 is offline
Escort guy
Re: Shifting Problem. Please Help Out
Welcome to AF!
The first thing to check is the level of trnsmission fluid. Get the car up to operating temperature and leave it in park or neutral with the engine running. Check the fluid qauntity with the dipstick. Level should be between add and full mark. The more serious problem is why the tranny is low on fluid. Check for red oil spots under where you park the car.
Old 03-28-2010, 10:34 PM
Scrapper Scrapper is offline
AF Premium User
if you let this go to long on sliping or reving up to try to go i would say you burnt up the automatic clutch bands? i would change filter and fluid in tranny. your tranny module could have went bad but like i say if you tryed pushing it to hard to try to get it to go i'd say then new tranny needed.
Old 03-28-2010, 10:52 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Yes, I think you need a new tranny or a tranny rebuilt. The piston clutch of 1st and 2nd gear may be damaged, so it slips.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 03-28-2010, 11:17 PM
Escort guy
The piston (servo) for 1st to 2nd gear may be bad because of bad line pressure to the clutch pack. If the discs in the clutch pack are worn excessively you need to consider a rebuilt transmission. Although a fluid change may help it will in no way be a solution to a remanufactured transmission.
Old 03-31-2010, 06:49 PM
Thanx for giving me some ideas guys !
I kind of was thinking that it could be the trany.. Had done the trany flush and new oil was put in it about 4 years ago. I will check on it, see how's my oil level.
Thanx again
