Old 03-27-2010, 04:10 PM
meggabad meggabad is offline
2001 Z71 Differential Bearings
Both of my differential seals are shot, I'm planning on replacing both half shafts and seals. My question is, isn't there bearing assemblies for each side, and how difficult a job are we talkin' to replace those bearings? I can't seem to find any information on what to expect after shaft removal such as do these bearings just sit in there..etc.
Old 03-28-2010, 08:58 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2001 Z71 Differential Bearings
See if these will help.
Rockland Standard Gear, Inc_ Differentials; Ring and Pinion.mht
http://www.differentials.com/install.html
http://www.rsgear.com/articles/articles.asp
MT
Old 03-28-2010, 03:36 PM
The first link describes rear diff and the second link is broken. Thanks but this didn't really help...
Old 03-28-2010, 04:29 PM
MT-2500's Avatar
AF - Advisor
The bearings very seldom go bad.
The axel tube on right side has to be removed to get to bearing and seal.
left side stub shaft has to be pulled to get to seal.
Is stub shaft axel is not lose or shaft pitted where bearing runs I would not replace bearings.
MT
Old 03-29-2010, 11:13 AM
Ok thanks, I'll let you know how it goes.
Old 03-29-2010, 12:03 PM
MT-2500's Avatar
AF - Advisor
Also make sure vent is open when you replace seals.
MT
Old 04-01-2010, 08:59 PM
Really? No problem and thanks, but why?
Old 04-02-2010, 08:46 AM
MT-2500's Avatar
AF - Advisor
A plugged vent will build up pressure and blow/make seals leak.
MT
Old 04-03-2010, 01:16 PM
I understand now, I thought you were talking about the top fill plug for some reason when I read your post......duh! Thanks for mentioning it, I might overlooked that.
Old 04-06-2010, 09:44 PM
vnotaro vnotaro is offline
I also have to replace the left bearing and seal. These differentials come in 9.25 and 8.25 ring gear configurations. Are the output shaft seals and bearings the same for both diffs? MT-2500, thanks for the heads up on the vent. I would have overlooked that too.
Old 04-07-2010, 08:25 AM
MT-2500's Avatar
AF - Advisor
There is 2 different seal.
Not sure what seal for what rear ends.
best to match up o measure old one.
Is the bearing bad?
If so it may have damaged the axel to.
Check where the axel bearing runs for damage.
If so they make a axel saver bearing for them.
Also make sure the rear axel vent is open to.
MT
