Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 03-27-2010, 07:36 AM
MHardee1 MHardee1 is offline
2005 Escape MAP Sensor Bad?
Intermittent stalling coming to stop.. I hooked up AutoTap (outside environment was approx 65 degrees F & sunny - nice day) to read and discovered:
Engine load at idle read 21%
Ambient Aire Temperature 23 degrees F (It was 65 really)
Barometric Pressure 99 (would this not be the same as 5 atmospheres?)
Does this indicate the MAP sensor has taken a dive?
Thanks for any help
Old 03-28-2010, 02:11 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Re: 2005 Escape MAP Sensor Bad?
You dont have a map sensor....you have a mass air flow sensor...and if the pressure readings are significantly different than the real ones (look up your weather on weather.com or something similar) then you have either a wire issue or a bad sensor.
Old 03-28-2010, 07:44 AM
MHardee MHardee is offline
Thanks for the reply.. the environment reading are very different as noted in my initial question.. I will continue to investigate the wiring and clean the MAF sensor first (the air filter was very dirty).
I heard a "buzzing" coming from the area around the MAF sensor when hooking up the scanner. It would start about 10 seconds after Key On Motor Off. Stopped when I reset the codes.
Any way to check it with a DVM?
