Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-26-2010, 03:41 PM
cjstew4 cjstew4 is offline
Should I get a 5.3 or 4.8 Tahoe when no towing expected
Looking to get a Tahoe or Yukon. For 2000 and newer models, first is mileage better with 2WD 4.8 or 5.3L engines? Second, is one engine size better for reliability? I do not plan to tow or carry full loads. Are there any years and/or engine sizes that I should avoid. Just donated my 97 Venture after is second head gasket blowout at 195k mi, but want to stick with GM. Thank you.
Old 03-26-2010, 04:46 PM
j cAT j cAT is offline
Re: Should I get a 5.3 or 4.8 Tahoe when no towing expected
the tahoe usually comes with the 5.3L engine ...this is the standaed size ...also they usually have 4WD ...with 2wd you will have a little better mileage and less componets to maintain...
with these vehicles you must replace transmission fluids/filter every 30,ooo-40,000 mi...also the GM APPROVED dexcool needs replacing with distilled water only every 3-4yrs...AT THE MINIMUN OF 50% DEXCOOL ..I use 65% dexcool, this is to control corrosion ...these engines will get corroded then the leaks !
replacing the fuel filter every 30,ooo mi / and keeping the fuel tank above 1/4 at all times prevents fuel pump failures..
you should expect 17-19 mpg on hywy with the 2wd...16-18 with the 4wd..
the 2wd driverside spring usually needs replacement ...common issue ..
these are heavy vehicles you will need a 5.3L engine...unless your not gonna drive around where there are hills/mountains...you got plenty where you live !
Old 03-27-2010, 09:25 AM
thanks jcat for the tips. Hopefully the dexcool with do a better job than it did in my Venture when I get a Tahoe.
Old 03-27-2010, 11:47 AM
iroc343 iroc343 is offline
Hold out for the 5.3, fuel mileage is the same but more power and higher resale.
