Old 03-26-2010, 11:05 AM
Jasoncmor Jasoncmor is offline
Model Painting help
Hi all.
Model is a Tamiya R33 GTR Vspec.
The model was lightly sanded with 800 grade wet / dry sand paper.
Then washed in warm soapy water and left to dry.
I applied a very light coat of Tamiya Plastic Primer, then after that dried sprayed another light coat, but slightly heavier.
After that dried, I added another 2 coats of primer, not too thick, but it looked spot on after I had finished it.
I left the model to dry in a food container, with the lid on and a small hole in the bottom for 24 hours. ( that was yesterday)
Today, roughly 24 hours later, I lightly sanded the primer with 2000 grade sand paper and washed it again left to dry.
The paint is Zero-Paints Midnight Purple LP2.
Air brush is just a cheap hobby one, nothing special, but its good for a beginner with air brushes.
I sprayed a very light coat of the paint and gave it time to dry and then sprayed another light coat of paint, still could see a little primer through the paint.
After that dried, I gave it another coat and noticed the paint look funny.
It felt rough too.
After it had dried, I wet sanded it with some 1200 grade sand paper and let it dry off, then started airbrushing again.
The bonnet and roof where I spend most of the time sanding look better, But everywhere else looks the same.
I'm wondering weather this is what you call shrinking effect with the primer?
I've used food containers with this model to try and keep dust out of the paint work, with just a small hole in the bottom.
I need help.
I don't know what this problem is?
Thanks
Old 03-26-2010, 12:36 PM
Some_Kid's Avatar
Some_Kid Some_Kid is offline
Re: Model Painting help
Looks like you need thinner.
Old 03-26-2010, 01:24 PM
How can I strip the paint off the model?
I stripped another model off the other day using some revell painta clean, with a non scrtach pad, but apart from the price of it, the smell is so deadly, it leaves me gasping for air.
Paint comes off quite easily, but you need to scrub it really well and you need to sand the model after aswell because the surfaces are left rough.
Old 03-26-2010, 02:25 PM
Some_Kid's Avatar
I think the best way is to store some break fluid in a tupperware container. Keep it in a safe place. It will strip the paint in about a day. Keep tabs on it.
Old 03-26-2010, 06:42 PM
pharr7226 pharr7226 is offline
I've forgotten about parts and left them in brake fluid for over a month with no bad effects on the plastic.
Old 03-28-2010, 08:12 AM
Does it matter what type of brake fluid I use?
I just looked on eBay and there are different types like DOT 3, DOT 4 and DOT 5.
Cheers for your advice.
Old 03-28-2010, 12:01 PM
Some_Kid's Avatar
I use DOT 4 and you can get it at Walmart or autozone, no need for ebay.
Old 03-28-2010, 12:53 PM
MidMazar's Avatar
MidMazar MidMazar is offline
any brake fluid. Also 91% alcohol works just as good if not better and its cheaper. Usually $1 at your local drug store.
In Progress
Old 03-28-2010, 09:26 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Do not use brake fluid. DOT 3/4/5 can destroy any plastic part at any time. It may not destroy all parts- but you would be unwise to place in it any body (or other parts) that you cannot cheaply and easily replace.
Iospropyl alcohol is entirely plastic safe, and it will strip automotive lacquers very effectively. It is also much less toxic (for you/your family/your pets/the environment/etc), and easier to dispose of.
And that means precisely nothing.
You can put an antelope into a cage with a lion. He might last an hour. He might last a weekend. But even if he does, it in no way means that lion's cage's are a good place to keep antelopes.
Sure, everyone knows that brake fluid will destroy paint. But a good paint stripper that does not make it.
PHOTOBUCKET SUCKS
Old 03-29-2010, 05:06 AM
countach79's Avatar
countach79 countach79 is offline
awesome analogy! poor little antelope
Old 03-31-2010, 04:30 PM
Didymus Didymus is offline
If the paint looks rough and pebbly when you're applying it, it's too thick, and it won't smooth out as it dries. Don't worry about coverage; thinner paint will cover just fine.
For stripping, I like Purple Cleaner from Allied Auto Parts, or 91 percent isopropyl alcohol from the drugstore. You can also try mixing them or using them in tandem. After a three-day soaking, use a brass brush to remove the residue. It won't damage the plastic like sanding will.
Good luck!
D D M S
