Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-24-2003, 10:05 PM
syne164 syne164 is offline
bose
i have a 200 watt bose system in my maxima can i change the 8 inch subwoofer to a jl audio and add a 250a punch amp ? how can i do that and leave the stock amp for my stock speakers please help thanks?
Old 04-25-2003, 02:51 PM
MaxPayne MaxPayne is offline
Send a message via AIM to MaxPayne
What I did was simply tap into the lines between the individual amps and the speakers in the rear. Use that signal for high level inputs to the amp for the sub. Also, if you only have RCA connections, or only want to use RCA connections, you can get high level/low level audio converters. I forget what their official name is or part numbers, but they aren't that hard to find.
Old 04-30-2003, 12:54 PM
cam_honestiam cam_honestiam is offline
STEREO
I just finished installing my subwoofer/amp. If you need a converter, there is a brand called "PAC" and it is a high/low impedance adapter (officially). Prices vary, but I can get some knock-off brand at a pawn shop for $15.00--You need to tap in from the signals (as stated earlier). The converter is a little box with four colored wires, two brown wires, and two RCA connections. You tap into the right and left rear speakers (not the red or black lines, the multi-colored ones...the red and black are power and ground for the individual amps on each speaker) and then plug in the RCA's. You will have some issues with quality loss (at least I did), and it would help if you have a crossover to filter out the mid/higher frequencies. If you want to use a seperate amp, you will have to disconnect the pre-amp on the speaker. Good luck!
Old 04-30-2003, 02:57 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
The stock Bose sub is an open air sub. A JL is designed to be in a box, so I dunno how good it will sound in the rear deck.
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Old 05-01-2003, 01:56 PM
subwoofer
i just wanna change the subwoofer to get more bass and power it with my 250a punch amp what subwoofer is good i have a 8w6 jl audio is that good or what should i get please help thanks?
BOSE RDS Radio Theftlock Code? Steevow Envoy 0 04-20-2010 01:42 AM
Difference between Bose and non-Bose? alec_b Aurora 5 11-01-2005 02:49 PM
