Old 04-24-2003, 08:49 PM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
Differential question
Here's my question, I understand gear ratios, differentials and why it is nescessary to have both. But, why have a gear reduction in the differential (rather than 1:1) when this could be accomplished by adjusting the transmissions gearing to compensate. The only reason I can think of, being the need to keep a transmission more compact, and doing so by inserting a gear reduction that will effect all gears so the gearing in the transmission need not be as severe (and space consuming). Opinions? Again, I understand how all this works, I am only asking why we need a reduction in the diff.
Beer tastes better upside down.
Old 04-25-2003, 12:05 AM
texan's Avatar
texan texan is offline
Writer Mod
That, plus the ability to quickly change overall gearing by replacing one ring and pinion. Gearing, ideally, should be optimized for each individual application, and it'd be very expensive to generate that many different gearsets for a transmission.
'03 Corvette Z06
'99 Prelude SH
Old 04-25-2003, 01:56 AM
FYRHWK1 FYRHWK1 is offline
Send a message via AIM to FYRHWK1
Size as well, having the overall ratio for 1st gear solely inside the transmission would increase the size of the unit, plus since you need a rear differential, why not make use of it?
Old 04-25-2003, 10:27 AM
SaabJohan SaabJohan is offline
Also, if the gear ratio in the differential was 1:1, the torque transfer from the gearbox must be higher since the same power should be transfered (and the driveshaft will now rotate slower). Because of this the gearbox and drive shaft must be made stronger and therefore heavier and bigger.
Rear differential question. jason635csi 6 Series 13 09-06-2007 12:20 AM
Ram Differential Question LTJGWorth Ram Pickup | Ram SRT10 3 07-23-2004 05:40 PM
tire & differential questions canyonblue77 Crown Victoria 1 06-24-2004 02:35 PM
Auto to manual conversion Rear differential Question caper 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 8 08-11-2003 12:38 PM
differential question natedogs911 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 11-01-2002 05:26 AM
