Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-24-2003, 12:58 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Chipping for a turbo
I am going to be running a t-25 with two side mount eclipse intercoolers. I am going to use 440 cc injectors if I cant get info on chipping the computer to deliver more fuel. If I only run 6psi would it be a must to run the bigger injectors or could I buy a "mugen" chip from ebay. With only 6psi would I have to do anything to the fuel system to be safe? Also I am wondering about how to tap the back of the motor for an oil line.
Old 04-24-2003, 07:24 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I would think that your stock fuel system would be enough for 6 PSI. I am not sure about the oil line, you would need a Honda expert for that. You will need to get a piggyback or a standalone computer to drive up the fuel/ait ratio. I suggest that you invest in a fuel/air ratio guage to keep an eye on that as well.
And for 6 PSI, you hardly need two intercoolers, one will do you just fine.
Old 04-25-2003, 08:30 AM
Registered User
Thanks alot I am going to be building a motor and running more bosst thats why I wanted to go ahead a use two intercoolers. But I think to save a little money early on I will just get one and then get a FMI when I get the motor built.
Old 04-25-2003, 02:05 PM
Polygon's Avatar
The Red Baron
That's a good idea.
Good luck with your project! Sounds like fun!
98 SH LEWD VS. Chipped Jetta Turbo lewd98h Prelude 4 05-17-2007 03:12 AM
FOR SALE Autotech Q-Chip for 2.0l 92 Passat blownrx7 '88 - '92 0 09-26-2005 10:17 AM
I'm looking for an ECU chip for my 1996 Sunfire GT ROLONDO Cavalier 3 10-25-2003 12:09 AM
Whats the best chip for 2000 VR6? (P-chip?) DBPD '97 - '03 2 07-31-2002 03:50 PM
jett chip for sale for 93-95 lightnings speedracer027 F Series 0 02-15-2002 01:53 PM
