Old 04-24-2003, 09:53 AM
neufeld3 neufeld3 is offline
Electrical Problems
I've got a few electrical problems, first my headlights stopped working, along with the cruise control. I had a similar problem in a previous car and I replaced the altenator and it took care of the problem. I also plan on checking the fuses. Is there anything else I should take a look at? I'm hoping it's not a major issue like a short or somthing. Also has anyone replaced an altenator before on a 96 civic ex? I've done this before on other cars...any help would be great.
Old 04-24-2003, 10:26 AM
94civic's Avatar
94civic 94civic is offline
check the harness for the headlights, there might be a cut wire or something. thats what happened on my car, on the right side the low beams kept on going out and then i checked the harness the was a exposed wire. looked like something was chewing on it
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 04-25-2003, 03:41 AM
tenzoracerevovii tenzoracerevovii is offline
not sure about your other questions, but i definately think you should check the fuses first. i remember when i put my amp and subs back in my car, i installed everything including a head unit, then took it out, then put it back in again because the subs weren't working, then i found out my power wire fuse blew out. how stupid.........
i have type-r stickers on my bike, will it go faster?
-me
Don't you know, it's 10 hp for every sticker, 50 hp extra for every additional inch of rear spoiler behond stock height.
-obiewancoyote
Old 04-25-2003, 11:10 AM
I checked the fuses last night, none of them were blown. I took off the front bumper to get a closer look at the bulbs and I think I found the problem. The harness (the thing the bulb plugs into) had all kinds of corrosion on it. A white puss like stuff that kind of looked like battery acid? I thought that was weird. Also I have a set of plama bulbs in the car, the cheap ones off e-bay. Is this the source of the problem? Anybody have a similar thing? Also how hard is it to put a new harness on. Should I give up and take it to a shop? Oh yeah one more weird detail, both lights are out and the bright light indicator on the dash stays on, even when I switch it off. Almost like the switch is stuck in the open position.
Thanks
Old 04-25-2003, 12:02 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Yeah that could be your problem. I've seen them fry the plug on the harness and have heard it happens pretty often with certain bulbs. I just stick to regular old bulbs.
Old 04-26-2003, 12:37 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
my left reverse light plug is like that....it works sometimes.....does the dealer sell new plugs or.....is there no hope.....duh junkyard.....but does anyone know if the dealer sells the plugs? or harness or whatever you guys call it
2002 Acura TL Type S
1991 Honda Crx Si
