| Latest | 0 Rplys |
WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
03-18-2008, 07:13 AM | #16 | ||||
Re: Tamiya 1/24 Ferrari F40 - progress
Thanks for all the comments!
Here's the finished effect mixed with the paint for comparison
Rob |
03-18-2008, 12:48 PM | #17 | |
Amazing details man! This will be one intersting thread to follow up. So, keep it coming!
03-20-2008, 06:36 AM | #18 | |
Mate, you so should be working for Tamiya...
Fantastic as always! |
03-23-2008, 12:40 AM | #19 | |
Not much in the way of step by step progress. But here's a picture of the engine at the moment. Lots still to do...
I made replacement turbos to replace the awful kit pieces.. they still look ordinary in these photo's but you can see how small they are and once on the kit should look the business I've also started on the wheels by machining the centre out from the kit wheels and then made resin copies The original wheels are 17" but I prefer the look of bigger wheels on scale models so I've stepped the machined rims to make them look slightly bigger without affecting the ride height or changing tyres. They aren't that much bigger but improves the look don't you think? More soon....
Rob |
03-23-2008, 02:13 AM | #20 | |
Those turbos just blew my socks off!!
Guideline for happy modeling: Practice on scrap. Always try something new. Less is more. "I have a plan so cunning, you could put a tail on it and call it a weasel" - Edmund Blackadder |
03-23-2008, 03:45 PM | #21 | |
Wow, excellent work. Can you go into more detail about how you made the turbos?
03-23-2008, 04:08 PM | #22 | |
lovly work on the engine!
And thnx for awnsering my question |
03-23-2008, 08:34 PM | #23 | |
AF Premium User
Abolutely beautiful!
In Progress: FXX - test mule in CF 49' Mercury |
03-24-2008, 07:02 AM | #24 | |
Immpressive detail engine.
03-24-2008, 01:21 PM | #25 | |
awesome work, man I missed your progress threads
05-03-2008, 02:53 AM | #26 | |
Here is a quick update.
I mentioned earlier that I am making new wheels so here is the progress. First I made resin copies of the wheel centres To make the machined rims I decided to do them in two pieces, the actual rim and the section which bolts to the centre. The reason for doing it this way is 1st, it made it easier to mill the bolt holes and 2nd, I can adjust the offset when I'm finishing the model to get a nice fit. Here you can see the 3 pieces and then almost completed pictures (I still need to find bolt heads to use) More updates soon.
Rob |
05-03-2008, 03:41 AM | #27 | |
Lovely job, Rob!
How about making your own bolt heads?
05-03-2008, 06:01 AM | #28 | |
Before I started on the paint I needed to fix a few problems with the kit.
The first is the air inlet next to the side windows The kit simply has this section added to the window and asks you to paint it red. On the actual car this part is shaped to direct cool air into the engine. I forgot to take a picture of the glass in the kit but to fix the model I made a template of the shape and then used putty to form the intake I then sanded the groove and after a bit of work it looks OK Thanks for watching
Rob |
05-03-2008, 08:46 AM | #29 | |
i can only say for those who has machining assessibility / capability, you do have a absolute advantage over us (the plastic builders).
i hope for all those precision works you've made into this build, will shine out better than those who uses only plastic. let's see what you can do on the completion. good luck! marc SGP
I can feel the adredalin, the same adredalin of what it's like... to be a classic ferrari coachbuilder.
05-04-2008, 03:56 PM | #30 | |
Zero Rosso Corsa basecoat applied. Clear coat to follow soon.
I've also done a bit more on the rest of the kit Thanks for looking
Rob |
