Old 01-05-2011, 03:54 PM
kans0002's Avatar
kans0002 kans0002 is offline
Re: ARTA NSX 2005 - Tamiya - 1/24
damn man...damn
Old 01-06-2011, 06:34 AM
Macio4ever's Avatar
Macio4ever Macio4ever is offline
Steereing wheel is on the bench. I am struggling to get good lettering printouts. After two hours I got satisfactory results.
This is how I'd like wheel look like:
Printouts on photo paper, HP 7600, 600dpi (blue arrow). I have backup plan to use yellow ink on transparent decal (red arrow). Will see - I will test both methods and show you results.
They are readable and when printed on decal paper should easily conform to steering wheel curves.
Macio4ever
www.mgsf.pl
Old 01-06-2011, 07:22 AM
das_auto's Avatar
das_auto das_auto is offline
Insane detail Macio! lovely work!
//Emil
Old 01-06-2011, 01:37 PM
MAXIMA2278's Avatar
MAXIMA2278 MAXIMA2278 is offline
Originally Posted by Macio4ever View Post
I have finished paddles. They are thinned as they were too thick and out of scale. Decaled with 1/43 SMS carbon decal to keep it in scale.
I have also added connector for steering wheel cable (red arrow). I used HD knob switch (0.75mm dia) drilled with 0.3mm drill to connect cable.
Steering shaft will be glued later affter final dash assembly.
And quick photo to show scale. Coin is a bit smaller than 1 Euro cent
Once again: thank you for watching and all nice and motivational comments.
You are a modeling GOD!!!!
Old 01-07-2011, 07:56 AM
Macio4ever's Avatar
Don't tell it to anybody Human, or... you might wake up as Tamiya putty
What's next - steering wheel is on the bench. I will describe modifications more in detail - maybe some of you will find it useful. Plan is to decal wheel, add own lettering, add signal lamps and make it as clean as possible. I see 2 difficulties: decaling knobs and masking.
Why?
Knobs and switches are on very small area so decal will probably conform but carbon pattern will be deformed. Masking is hard as I may easily destroy decals. Will see what can be done.
Step 1: Putty, sanding and primer - only one layer as the details are delicate.
Step 2: Drilling and removing switches. I will use HD knobs for two bigger ones (CM-A/B) and my own for the rest. I remove knobs to make decaling easier and more clean.
HD knob dry fitted only.
Step 3. Semi gloss painting (Gunze). Form this point all have to be max clean and there will be no much room for the mistakes.
Step 4: Decaling process is started. I have used SMS 1024 carbon decal. When it will be dry I will put my own decals and Honda logo.
Stay tuned,
to be continued...
Macio4ever
www.mgsf.pl
Old 01-07-2011, 09:24 AM
racer93's Avatar
racer93 racer93 is offline
So, you're going to keep the doors closed on this? Or, are you going to try to have the windows down? (Do these windows move [don't think so, but...]?)
Great build. I have a "PIAA" version that's in process (read: stopped) right now and I need to finish it...keep it up!
Daniel
Old 01-07-2011, 09:27 AM
LeeABC's Avatar
LeeABC LeeABC is offline
magnificent! you're doing a wonderful job, I love to see this level of detail.
Cheers, Lee
Old 01-07-2011, 09:44 AM
Macio4ever's Avatar
Windows do not open as far as I know. The doors will be shut maybe in the next model I will open them.
The windows in the kit are second to none in terms of transparency so all the detaills should be visible. I have tested it and you can easily see panel details from outside of the model.
Step 5: Decals. They were prepared in Corel, few copies to choose best printed (see: background of the picture). Printed on BMF decal paper and secured with Microscale Liquid Decal Film - airbrushed, thinned with Tamiya X-22a thinner.
They came pretty decent but they are not Cartograf but I am quite happy with the result. Tested on scrap. I will do another copy on laser printer and see if it is better or not.
Thanks for watching!
Macio4ever
www.mgsf.pl
Old 01-07-2011, 10:54 AM
rollin80s rollin80s is offline
this is just insane attention to detail. keep up the fantastic work cause im loving it.
Old 01-07-2011, 02:29 PM
to-mek to-mek is offline
Amazing interior detailing, would be nice to open doors.
Old 01-09-2011, 09:21 AM
Macio4ever's Avatar
While waiting for printing my decals on laser printer I went back to the dash. I decided to make again antennas with different approach. I drilled 0,5mm rod with 0,5mm drill and glued 0,45mm plastic rod. I made few for this model and Raybrig and spares just in case.
It made painting easier as well.
Ready to be glued. I added PE screw imitations.
Dry fitted. It is 4,5mm high
Macio4ever
www.mgsf.pl
Old 01-10-2011, 10:17 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
The detail on the dashboard is incredible. Thank you for continuing to post such inspirational work. You are a true craftsman and master modeler.
-Mike
Old 01-10-2011, 12:46 PM
kemilk kemilk is offline
wspaniala robota...tylko pozazdroscic
Old 01-10-2011, 01:11 PM
Miodzio20 Miodzio20 is offline
very nice and great job... i wspanialy polski akcent
Old 01-10-2011, 01:21 PM
klutz_100's Avatar
zgadzam sie
Tamiya 1/24 subaru impreza 2005 monte carlo - solberg audi_racing Completed Projects / Gallery 9 12-01-2008 07:49 AM
Arta Nsx 2005 karls0415 WIP - Motorsports 6 07-01-2008 12:34 AM
Honda NSX Mobil 1 - Tamiya 1/24 Macio4ever Completed Projects / Gallery 8 02-29-2008 09:59 AM
NSX Mobil 1 - Tamiya 1/24 Macio4ever WIP - Motorsports 83 02-26-2008 12:08 PM
Tamiya 1/24 Honda NSX - Completed PICS Captain Mark Completed Projects / Gallery 11 09-22-2005 08:25 PM
