Old 04-10-2010, 09:41 AM
das_auto's Avatar
das_auto das_auto is offline
Re: 1/24 Revell Corvette C6R
Itīs amazing how well youīve got the stance of the car dialed. Itīs not often a 1:1 stance can be replicated successfully in scale! Viewed from the side it looks soooo real!
Good Job Cife!
Old 04-12-2010, 02:25 PM
rx7king's Avatar
rx7king rx7king is offline
Those windows are incredible, worth the extra work!
Old 04-13-2010, 04:36 AM
sjelic's Avatar
sjelic sjelic is offline
No words really, you did fantastic job, every single detail look perfect.
Sasa Jelic
SCALEMAKERS
Old 04-13-2010, 07:39 PM
da_ashman's Avatar
STUNNING!!! Beautiful work, amazing detail & superb finish
Old 04-14-2010, 09:32 AM
CifeNet's Avatar
CifeNet CifeNet is offline
Thank you guys.
Good Job Cife!
Funny you mentioned it, the ride height can be actually changed. I drilled holes for wheel metal shafts which connect the wheels together to the chassis and the holes are horizontally enlarged.
It is tight fit, but I can set the ride height. If I push it enough, the car gets lowers and vice versa...
I should have glued the shaft to the chassis, but I didn't...
-- CifeNet
Old 04-15-2010, 06:34 AM
Robi J's Avatar
Robi J Robi J is offline
Outstanding craftmanship, as usual. Not to mention the photography...
Everything is fantastic.
R
Old 01-27-2011, 07:31 PM
alviga69 alviga69 is offline
Hello:
very impressive WIP
i am just starting the same kit, but it will be OB
i have a doubt about color
some friend told me that the yellow color is metallic
is that true?
ihope you can help me
best
Old 01-28-2011, 01:58 PM
Stubeck Stubeck is offline
Its not metallic.
Old 01-28-2011, 10:11 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Nice someone brought this one up because i wanted to ask you if you used the same size rivets on the rear window? Also how did you do the black dots on the front headlights. This C6R still is my fav to date with the badboy vette right behind!
In Progress
Old 01-29-2011, 01:53 PM
Originally Posted by Stubeck View Post
Its not metallic.
Thanks for the answer
one more question, do you know the name of the yellow color for this sport car?
any suggestion maybe in Tamiya spray cans?
Cheers
Old 01-29-2011, 03:02 PM
The Tamiya Camel Yellow is supposed to be a good fit, I used Chrome Yellow on my C6 and it turned out well.
Old 01-29-2011, 04:40 PM
123yokomo's Avatar
123yokomo 123yokomo is offline
wow great progress i built one years ago great one
Old 01-29-2011, 11:47 PM
Thanks a lot,
Old 06-11-2012, 12:08 AM
Shunter's Avatar
Shunter Shunter is offline
I really hate to dig up such an old post, but then again it was a great build. Steve i was curious to know how you hinged your front doors?
Cheers
Shayne
http://motorsportmodeller.blogspot.com.au/
Old 06-12-2012, 05:11 PM
f40 f40 is offline
Thumbs up Re: 1/24 Revell Corvette C6R
Stunning!!!!!
