| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
| WIP - Motorsports Post topics for any "Work In Process" motorsports vehicles in this sub-forum. |
Show Printable Version | Email this Page |
#76 | |
I could only dream on doing all that by myself! Amazing stuff man Truely Amazing
#77 | |
Re: Eighties Contest Entry: 1988 McLaren MP4/4 (and Introduction)
wohaaa, what a ride. Your work is truely amazing. I'm standing up bowing for your VERY inspirational work!
/joel
Visit my FB page www.facebook.com/one12th |
#78 | |
Oh it's fluo red again:-)
Well Marcelo don't worry....it will get the "right" colour! :-) ( Check back to the beginning of the thread...) Last year all of Senna's McLarens were lined up in a row at Goodwood and i could do the comparison: ![]() ...and ever since i get jokes for this from friends. ( Hey Martin! ) These were samples of RAL2005, 3024 and 3026....and they'll look wrong in this picture on your screen! I'll paint the stripes with 2K-RAL 3024 fluorescent red. That's what McLaren must have used ( no 3-layer system is my guess ) so it should be fine for my model. The available modeling paints all have a tendency to loose their shine or change over time and they "die" under clear coat. The really unhealthy automotive stuff lasts better:-) That said it will also get wiped out if you put it in the sun for a longer period. I worked in Rescue Service some time ago and they used the same paint for the ambulances there and the stripes painted in that colour kept getting "washed away". These days they use stickers to replace them easier! BTW....just to add to the confusion....McLaren used stickers on their cars for the numbers too ( nosecone ) and as could be seen at Goodwood they were not always a perfect match for the paint of the stripes.... Same problem goes for the model stickers. The ones that come in the kit are just plain wrong ( way too dark red )! I have a "normal" Studio27 '88 Japan GP decal set and i was lucky to still find one of the sold out "HighTech" sets as well. There's a noteable difference of the fluorescent red even between those two....done by the same company! ( The stickers from F1Specialties have yet another different shade...) I have found the High-Tech ones are the best match for the colour on my MP4/8 that's already painted so i will use them as well on the 4/4. Now to argue about the look of a paint shade over photos posted on the net is quite pointless anyway. I would try to match the paint and stickers you have and be happy with it. If it looks good for you that counts! I rest my case:-) So what next!? Ferrari "Rosso Corsa 2001" or Porsche 917 " Hippy Burple" anyone :-) :-) :-) Cheers! |
#79 | |
Great modelling.
When looking at your thread you have an idea and have the skills and balls to go for it. Good on you. Keep up the good work. |
#80 | ||
Zomby Woof
![]() Join Date: Nov 2002
![]() Ferrari 2001 is easy - paint it orange! |
#81 | |
INSANE!!! Awesome! Keep it up!
Best Regards Anton |
#82 | |
Hi everybody. After christmas holidays here comes a new update. I did manage to get some stuff done although not as much as I thought :-) Anyway here we go!
After my photoetching session I first shifted attention to another big obstacle….the wheels. The kit bits come like this: ![]() They are a good starting point but obviously need some attention. As I started checking my reference pics though, some questions arose. As you can see the wheel has 5 spokes instead of 6 and that was the case for both the MP4/4 chassis I photographed!? ![]() From my reference books though I looks like the cars always raced with 6 spoke wheels. Luckily Honda had those wheels on a MP4/5 at Goodwood in 2003 so here are shots from them which I used as a guide. ![]() My aim for the wheels and the rest of the suspension is to get them very detailed to keep them on level with what I want to do with the rest of the car. I does make you feel a bit stupid to build stuff that will mostly be hidden inside the wheels but where do you stop? :-) The uprights definitely will need attention where they get connected to the suspension arms later on because they’re clearly visible so the rest has to follow… The solution to that problem is quite obvious… the wheels must be detachable. Tamiya provides that with their “screws into the upright” solution…well kind of :-) It’s of course completely wrong because there has to be a centre wheel nut that goes onto a stub axle. So… i have to make my own working ones. In fact these here are my second attempt. I did that whole stuff for my MP4/8 already using brass hex rods ( and then stopped working on the model to do this one here…) but what comes now is an improved version. Plastic is no choice for fabricating those pieces so I used brass again. I started with 4mm round material that I turned to an outer diameter of 3.4mm and drilled holes inside, to then cut a M2 thread. ![]() The next step was to mill the hexagon shape for the nut using a “partition head”. I couldn’t figure out it’s name in English but it’s a device where you fix your piece in the middle ( like on a lathe ) and then you can turn it around with a degree scale for reference to make partitions….i hope that explains it. I don’t have a photo to show because I don’t have a mill yet and couldn’t take any during the working process. Anyway after milling and some cleaning up with 1200grit sandpaper and 3600grit polishing cloth my wheel nuts looked like this: ![]() Next up they went back into the lathe and I cut them off at the back with an angle that fit to the one I put into the front of the wheels. The result is here: ![]() As you can see I filled the front of the rims with polyester putty. Then I drilled a 2mm centre hole on the lathe and made the surrounding little holes using again the partition head and mill. They go all the way through. Here is a picture off the web from the real car’s hub/brakedisc/upright assembly. ( It’s a detail of a Rainer Schlegelmilch picture. I don’t have much more because at Goodwood they always left the wheels on the cars while I was there..:-( ![]() In the following picture you can see the pieces I made for the model spread out in front and sketch assembled in the back. There’s the wheelnut, stub axle and two photoetched pieces all made from brass. The axle is drilled hollow like on the real car. The thread is not really in scale but as good as I could get it. The fat end of the axle will go into the upright ( fixed with the little green ring ) and should be turning in the end while the wheel is fixed to axle, brakedisc and hub with the wheelnut. Thus the wheelnut will correctly turn with the wheel and not stay fixed like on the Tamiya solution……and I think it looks better:-) ![]() The green stuff I made the other pieces from is a polyurethane material used in professional model building. It comes in different densities ( hence different colours ) and is way better for milling and turning than styrene. It’s from the same “family” as the yellow foam in cans for house building and is sold for example as “Ureol” or “Necupur”. Originally I wanted to use the photoetched bits as drill templates for the holes in the wheels and hubs but that didn’t work as planned so I made them on the mill along with the ventilation holes in the brake discs. To make these assemblies go into the wheels I had to change them from the inside as well. I extended the centres with these green rings and made larger and deeper holes on the lathe. During that process I also got rid of the ejection pins on the backsides of the spokes and filled up the insides with putty. This I drilled out with a round milling head from my rotary tool ( aka Dremel ) on the lathe and then spent a lot of time cleaning/sanding by hand which is a really annoying job. On the right you can see two rims after their second layer of primer. Now there’s only some sanding left to do and then they’re ready for paint and the little brass pins I still have to do. Before that I have to do the uprights though which will include a lot of test fitting that could ruin a finished paintjob…..and I’m not really looking forward to that :-) ![]() While working on all this I also carried on with some other pieces. First up are the front wing endplates. The kit pieces are way too thick and also don’t look exactly like the real ones. To get better detailed ones I made PE bits. They were already cleaned up and primed before I glued them to 0.3mm styrene sheets as you can see in this picture. ![]() On the lower edge I added an angled strip of styrene that will later hold a wooden rubbing strip as per the original. You can’t see that in this picture but I’ll add one later when I get there:-) ![]() Here’s another picture after they are primered once more. ![]() I’m not going to drill the holes through yet. In fact I only put them in the PE bits because they would be really difficult to drill in those after painting. I learned on the 4/8 that even with sanding each paint layer there’s a “crater” building up around each hole and that looks bad. Besides you have to redrill the holes after each layer of paint and that increases the possibility of messing them up…..i know what i’m talking about :-) The same goes for the rear wing endplates. I rebuilt them from 0.3mm and 0.2mm (flap at trailing edge ) styrene sheet using the kit pieces as a template but without drilling the holes yet. I also added the angled surface running around the edge. ( In German we call that “Phase” but my dictionary didn’t know that meaning of the word…..seems to be less important than knowing how to order food:-) ![]() I also carried on working on the engine. The most prominent piece there is the plenum chamber on top. ![]() The kit piece that you see in the following picture together with the “injection system” that’s supposed to sit underneath leaves a lot to be wished :-) ![]() I worked on it a lot filing and sanding and adding detail with styrene rods, putty and PE pieces for the flanges. It is now filled from underneath and you can “see through” between the legs. Tamiya didn’t have a chance to do that correctly due to the injection molding process. While I was working on the little white bits in front of the first leg ( where the throttle linkage will go ) I realized the “neck” was too long. If you check the proportions in the last picture you’ll see what I mean. I decided to deal with it and leave it like it is because changing that would have meant it doesn’t connect to the intercoolers anymore and I didn’t wanna go there :-) The same goes for the cam covers. Their proportions aren’t exactly right but there’s no way I’m going to change them. ![]() ![]() I did cut off the connector plates and the Honda script because they’ll be replaced with PE bits and I added some details. The white bit on the left one is where the belt drive for the alternator sitting in the middle of the “V” is taken off. That’s one difficult piece I’ll have to build. ![]() You can find some great pictures of the engine at www.gurneyflap.com . I’m using those for details I can’t see on my pictures but won’t put them here. I now have the engine bits you see here primered and they need some additional work for cleaning and I’m working my way down to the exhaust and turbo assembly which takes a lot of time but I want them to look right and get them as clean as my patience permits… so for the moment this is it. By the way….in December I apparently exceeded my image hosting bandwidth because this thread is getting a lot of hits. I don’t want to reduce the number of pictures really so just in case that happens again be patient…or don’t watch them too often:-) They should appear again around the 16th of each month. Cheers Jaykay |
#83 | |
It's threads like these that just make me wanna jump from my chair, grab my tools and start building again.
Thank you. |
#84 | |
WOW
Chris |
#85 | |
Great update!!!
Rob
#86 | |
Educational.
Awesome. Incredible. Inspiring. Superb. This build is the most detailed 1/20th F1 I can remember for a long time. I am enthralled! |
#87 | ||
Registered User
Re: Re: Eighties Contest Entry: 1988 McLaren MP4/4 (and Introduction)
#88 | |
I am left breathless.... your talents are godlike.... I have no words but ....
KEEP GOING!!!!!!!!!!!!!! |
#89 | |
Sweet, sweet tiny Hondas.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2003
Oh my heck! This is incredible! I don't know why I haven't looked at this already. This is one of, if not the, most amazing build I've seen! Yet more reason why I hide from the motorsport section, you guys all make my cry with your skills!!
It ain't cool 'till your wife hates it. Imagine a world without Alabama Recent builds: Rocket Bunny FR-S and stock BRZ Toyota bB Bro-style Civic K20 powered SiR converted EK WIP I build slowly and poorly.
#90 | |
![]() Join Date: Jun 2005
