| Latest | 0 Rplys |
02-18-2004, 01:32 PM | #76 | |
Re: Low cost upgrades/modification??
Jeverett,
What horrible stories have you heard on the screen upgrade? |
02-18-2004, 02:37 PM | #77 | ||
Banned
Re: Re: Low cost upgrades/modification??
02-18-2004, 09:54 PM | #78 | |
the throttle bypass is where you un-hook the coolant lines that go through the throttle body, and just hook them back together with a brass coupler. Supposed to be good for a few horses. The stories I've heard about the screen are,
1.They smooth out air flow across the sensors, so by removing it, the air has moreu tuurbulance therefore screwing the air/fuel mixture up by not letting the ECU get accurate readings. 2. It doesnt keep some things out of the engine that get by the filter. I know if you have a good filter, this doesn't pertain. Some also have said that it also gave less power and mileage after removed. I didn't really know what was true, so I just put it back in. Its not hard to take out, so if I ever found the truth out, I'd remove it again in a heartbeat. IF I'm wrong, please correct me, I'd like to know the real deal. Last edited by jeverett; 02-19-2004 at 12:15 PM. |
02-20-2004, 04:28 PM | #79 | |
At the begining of this post, I was psyched and ready to pull the screen, now I am not so sure. I REALLY need mileage... I got 10.6 mpg on my last tank! It is a 6.0l, and I realize that, but it just gets worse, so any thing to help mileage, and performance of course would be great. I can't afford to lose any though, so should go for it, or not? Also, who has painted their calipers, and if you have, what type of paint, prepping process did you use. I have heard that the paint just wont stay, so I considered powder coating, but I imagine that could get pricey. PLEASE help with suggestions on the screen, I NEEEEEEDDDD the mileage!
02-20-2004, 08:14 PM | #80 | |
Banned
DAMN MAN TAKE YOUR FOOT OF THE GAS! 10.5mpg.. I sit you not i have a 2000 silverado with 6.0 and i get anywhere from 17 to 20 mpg. on a long trip i got 22mpg. i get anywhere from 560 to 600 miles per tank. here is my advice on the screen, aftermarket MAF dont have screens. why should the stock? but i would suggest a K&N filter just in case.
BTW 2000 Silverado 6.0 Dual Flowmaster 40 series deltas, K&N FIPK, B&M stage 2street/strip shift kit, and some cheap little sensor i got off ebay that really works!! |
02-20-2004, 09:21 PM | #81 | |
on the K&N FIPK do you think you are really getting the full 9.5 hp as claimed?
02-21-2004, 12:00 AM | #82 | |
use neverdull that works good on oxidation in referance to the mass air oxidation.
99 silverado 3" drop 18" custom american racing rims grond effects wipple supercharger 12psi pully edelbrock headers and catback custom leather and alpine audio system. nitrous kit soon 13.6 1/4 |
02-21-2004, 08:48 AM | #83 | |
Banned
thats a badass truck dog. on the FIPK.. you can DEFINATLEY feel the acceleration. alot faster throttle response. but my .02, go with the AIRAID. K&N is anywhere from 230 to 300 the airaid is about 100. i drove a friends with an airaid and it has about the same benefits.
02-22-2004, 10:10 AM | #84 | |
The AirRaid is only $100? Thats not bad, especially if it helps my gas! I will get an exhaust, I just dont know how soon, and prob a aftermarket maf. Thanks for the suggestions!
02-22-2004, 10:46 AM | #85 | ||
02-22-2004, 08:47 PM | #86 | |
screen
I took my screen out today and...........didnt notice a difference
02-23-2004, 02:21 AM | #87 | ||
Re: Re: Re: Low cost upgrades/modification??
the best thing to do is to reset ur cpu.. now about doing it on ur truck i dont know how but it is most likely u will have to pull a couple of fusses then turn ur truck on but not start it.. gm is known for using fusses to reset the cpu.. but i would buy a haynes book or something simular..the best thing to do after u reset ur cpu is to drive normal no wild driving for a few days to allow ur cpu to reprogram ur air to fuel ratio and so forth..by doing this u WILL lose some performance but thats normal for reprograming another thing not all trucks/cars are going to react the same to the screen removal. |
02-23-2004, 10:07 AM | #88 | |
Banned
to reset the ECU turn the key to the run position, not start just before it where everything is on. then fully depress the accelerator 3 times then shut the ignition off. then start back up. this works after adding a mod. it also clears off your change engine oil light.
02-23-2004, 10:56 AM | #89 | |
Okie...I bought a set of factory fog lights and just found out that the computer needs to be reprogammed to make them work. Will the ignition think work for me or do I need to go to a dealer?
Sonny |
02-23-2004, 11:57 AM | #90 | ||
wow thats a neat way to reset ur cpu/ecu thanks for the info ryan |
