Go Back   Automotive Forums Car Chat > Racing > Technical
Technical Discuss different strategies and theories of the racing aspect.
Old 11-24-2004, 11:13 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: Shifting
Staying on throttle while shifting is not as bad as launching the car ... you are basically doing the same thing: increasing revs before engaging the gear.
However, when you launch, you are "shocking" the system and you have to get everything moving.
At least when you WOT shift everything is already moving .... especially the wheels.
If you watch my in-car drag footage you will hear that the 3rd->4th shift is smoother than the others.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 12-28-2004, 07:18 PM
TeamFL1 TeamFL1 is offline
Re: Shifting
umm power shifting at the highest point of torque...........so power shift if ur highest torque peak is at 3,500rpm????????? wouldn't reving it all the way to the redline and shift be better tha power shifting at 3,500, if ur rve limit is at 7,600rpm???
Old 12-28-2004, 10:29 PM
AF - Advisor
Re: Shifting
TeamFL1, actually neither is correct
You do not want to shift at the torque peak for mazimum acceleration. And not all cars should be taken to redline either.
To find the ideal shift point you need to know your gear ratios and your torque (dyno) curve.
Old 12-29-2004, 09:51 AM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Shifting
Shouldnt you shift to where your RPM's will land right where your power band starts? Thats how i do it.
Old 12-29-2004, 10:05 AM
AF - Advisor
Re: Shifting
You maximum acceleration will come from staying in the thickest part of your power band across all of the gears you are using.
This is why you need to know the power band and the gear ratios.
It does you no good to shift at peak torque in one gear if you drop well below the powre band in the next gear. Conversely, it does no good to shift at redline in every gear if your power band does indicate that you are making significant power to redline.
Old 12-29-2004, 10:37 AM
CBFryman's Avatar
Banned
Re: Shifting
That is what i was saying. Example.
The Manual Tranny i am most used to driving is my moms Nissan Truck...well not the most high performance but when i fell like some get up and go this is how i shift.
I dont really "launch" because i dont drag but hey if i was i would hold the RPM's at about 3,500. Ive mesed around and any higher and i get wheel spin and any lower and i bog down a bit.
i bring the RPM's up to 5,200. This is where the engine really stops making power and the RPM's just creap up. it makes peak HP at 4800 (wow, lol 148 at the crank) but it hits its power ban late 3,000's. The gears are pretty evenly space but from 1st to 2nd at this RPM i usually get about 1500-1800RPM drop placing me at right at the bottom of the power ban. 3rd the truck really shines its short and the RPM's only drop 1200-1500 so i can bring it up to about 5,000-5100 and be put right back in a good ban. 3rd to 4th (im usually getting pretty fast now, around 70, much faster and im going faster than i want to go in a truck) i usually shift at about 4,800 then put it up into over drive.
Old 12-29-2004, 11:38 AM
Re: Re: Shifting
so if you car has very close ratios, you shift at the reline?
Old 12-29-2004, 11:52 AM
AF - Advisor
Re: Shifting
That would depend on your power band.
Example: The stock MR2T's turbo runs out of breathe above 5500 rpms and the redline is 7200 ... so not much worth racing to redline for even with close gears!
Old 01-04-2005, 08:00 PM
buymeabmwm3 buymeabmwm3 is offline
Re: Shifting
http://www.cyberstangs.com/autocalc/...hiftPoints.asp
1992 BMW 325i conv.
FOR SALE!!
IM me for more info. $6300 /obo
2005 Ducati Monster 620 i.e.
2005 Toyota Tacoma V6 4x4 Double Cab, TRD Off-Road - FINALLY HERE!
Horsepower is 100 ewoks poking you with pointy sticks.
Torque is one wookie pulling your arms out of their sockets.
Hard Shifting 2-3, no-shift 3-4 Geo99M6z C/K 7 05-26-2012 09:45 AM
04 impala Shifts Hard when Hot, P1811,shifts hard,jerks chevymandan Impala | Impala SS 3 10-09-2011 04:42 PM
Translab tl-175 Shift Kit or other shift kits for 3000gts 97mits3000gt 3000GT/Stealth 1 03-08-2004 11:50 PM
96 Jimmy 4wd shift motor/shift module Llogoaero Jimmy 4 12-09-2003 11:54 AM
burst of thrust/ hard shift when auto tranny shifts into second gear ERIKbronx Maintenance 6 04-22-2002 12:36 PM
