Old 10-14-2008, 03:19 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: b16a1 swap question
got my chipped p28 and ecu jumper harness today...ordered the Rywire obd-o to obd-2 distributor harness and going to get the 4-wire o2 sensor...i hope that's it
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 10-14-2008, 04:31 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
What basemap did they put on the p28? Do you plan on a tune? Before you go and get a 4 wire o2 I suggest just buying a wideband. One with 5v and 1v outputs (most of them) and use that as your narrowband so that you can monitor your AFR at all times. After that, welcome to being fully tunable bud! Next steps are an ostrich and hulog...then your ready for boost :P
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 10-14-2008, 04:32 PM
FrodoGT's Avatar
If your ok with a soldering iron i have been looking at this as a low cost wideband www.14point7.com But the innovate lc1 is good too, or a plx. My aem came with the gauge but only has one output so I still run my narrowband.
Current project:
Rio Red 91 hatch.
Old 10-14-2008, 06:18 PM
BLU CIVIC's Avatar
調整器
all of that is foreign to me for the moment
but good news...4 wire o2 sensor is still attached
he put a B16b basemap one it...VTEC engages @4800 RPM and rev limit @8500RPM and disabled the speed limiter
he called to see what basemap i wanted but could reach me, it isn't like i could tell him anyway...i just set foot into the world of Vtec and tuning
The name's Adrian
2011 CR-Z - Stock
Old 10-14-2008, 10:54 PM
FrodoGT's Avatar
Umm.. afaik there is no b16b basemap. its like the y8, obd2 and therefore runs on an entirely different system.
Current project:
Rio Red 91 hatch.
Old 10-15-2008, 12:00 AM
BLU CIVIC's Avatar
調整器
The name's Adrian
2011 CR-Z - Stock
Old 10-18-2008, 09:12 AM
BLU CIVIC's Avatar
調整器
well, started yesterday evening, in the rain...should finish today hopefully as long as my distributor harness comes in
The name's Adrian
2011 CR-Z - Stock
Old 10-18-2008, 09:36 PM
BLU CIVIC's Avatar
調整器
no distributor harness...darn you Rywire but the only thing that's left is wiring...and trying to use the OBD-2 injectors
The name's Adrian
2011 CR-Z - Stock
Old 10-18-2008, 09:47 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Damn... that looks so clean w/ the red valve cover in your bay... You gonna re-do the logo on the top of the timing cover?
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 10-18-2008, 09:56 PM
BLU CIVIC's Avatar
調整器
probably
The name's Adrian
2011 CR-Z - Stock
Old 10-18-2008, 09:59 PM
Pry have to do it in black then, right? I dunno dude, I hope everything goes great for you and nothing happens to your ride, but you accepted a huge risk when you put that motor in your bay.. There are alot of fuckers out there that would wrong a Honda just to turn a buck, and fuck the guy that put his life into building it up...
Good Luck.. Looks great.
Old 10-18-2008, 10:00 PM
BLU CIVIC's Avatar
調整器
i was pretty much a spectator during the whole process...i just watched, tried to help, and just held the flashlight...cost me $20 and McDonald's food to get the swap done
about 2-3 people in the area know what my actual engine is and this is the only site where i have it posted...since everyone knew i was getting a B16...i posted this
http://www.carolinahondas.com/showpo...4&postcount=15
The name's Adrian
2011 CR-Z - Stock
Old 10-18-2008, 10:09 PM
LMAO. Good Job. Now you're at least a lil safer.. don't show off your engine too much though, someone will notice what you've got, even though it's quite possible to paint a valve cover or stick a new (CTR) one on... they'll still see.
I"m thinking about building one more D-series engine... since I'm getting rid of the ZC, I'm thinking about building a SOHC Vtec... CRX HF (D15B8) block w/ D16 crank (you can make it work with machining) and Z6 head... with a combo like that, and the resultant compression from any piston/rod combo I've looked at, it's a good thing D-series parts are cheap, this thing might blow up a couple times. Another reason I still haven't been really working on going B-series lol.
BTW, if you paid for it and you were there to learn something from the install, you can still say you did it.
Old 10-18-2008, 10:19 PM
BLU CIVIC's Avatar
調整器
yeah, everyone that's helped me has been real cool...posting threads for me to ask questions so i won't draw any attention...but now i need to find OBD-2 injector clips, knock sensor, and a couple other things
The name's Adrian
2011 CR-Z - Stock
Old 10-18-2008, 10:22 PM
Are you using the stock ECU or the OBD-1 P28 you had?
If you're using and OBD-1 ECU, don't worry about using the OBD-2 injectors... you can steal the OBD-1 injectors from the B18 you pulled and insert them.
That will get you running for less money... and since you've already spent a hefty sum on the motor and suspension, I'm sure you'd like to find something "free" lol.
