Old 11-15-2006, 02:34 PM
quadzero's Avatar
quadzero quadzero is offline
Re: Group Build: Lotus Super Twelve
This is a great project. Fantastic scratch-building. I think how you hinged the nose is perfect and elegant. The rear suspension is excellent, keep up the great work on this uber-cool model.
Old 11-15-2006, 06:55 PM
rsxse240 rsxse240 is offline
I think it needs a cover over the top of the engine that exposes some of the intake plenum, and the airfilters to come out the sides. it could be fixed to the engine, and removeable with hood pins.
I honestly didn't think it'd turn out as good as it is. keep up the great work!
Old 11-23-2006, 02:44 PM
Martin S's Avatar
Martin S Martin S is offline
Small update..
Since last time I tested the stance of the car and realized that the track of the front axle
was way to wide. It didn't look very good when it had the same width as the rear fenders so I
had to modify the A-arms and the trackrod..
Oh well... at least it looks better now.
Have made some cycle fenders from the rear wheel housings of an old scrapped porsche 959.
On the inside I made a connecting bracket to the hub. Still a little rough:
A stance test:
Latest progress:
Ferrari F40 LM Fujimi 1/16 and Porsche 959 Fujimi 1/16
Finished:
1940 Ford pickup and Lotus Super Twelve
Old 11-23-2006, 03:05 PM
klutz_100's Avatar
Great stuff, Martin!
Old 11-23-2006, 03:21 PM
wow, that looks sweet with those monsterous wheels and wheel tubs.
Old 11-26-2006, 05:09 PM
Martin S's Avatar
Sunday night update with the progress of this weekend. Hope I'm not boring you to death with the detailed build descriptions..
Today has been "cool" day, with lots of radiator fabrication
I've scratchbuilt an oilcooler for the transmission. It will sit on the rollbar behind the driver.
I began by sandwiching some textured styrene sheets to make the cooler core.
Then I made the small fans by glueing small wings to a cylindrical center piece cut from sheet styrene with a belt hole puncher (great tool..)
To attach the fan to the cooler and to resemble a fan motor I took another cylinder of styrene and drilled three 0.45mm holes from the side.
Then I glued some wire in the holes.
The fan was glued to the "motor", the three wires were bent and inserted in drilled holes in the cooler core.
The oilcooler assembled (18 x 9mm):
I have also scratched the main radiator in much the same way:
It will have one bigger fan.
The fenders have been primered and attached to the hubs. I really enjoy making theese pin-locator fixing elements.
It's soo much easier to build and paint when you can test-assemble and dissasemble the hole car many times without using any glue.
Here is how far I have come. You can also see the begining of the roll-bar:
Latest progress:
Finished:
Old 11-26-2006, 07:42 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
You sick monkey.
I love how this is coming out. Crazy ambitious, but you're really making it work! Great thead to keep an eye on. opcorn:Your scratchbuilding skills are terrific as ever. (And don't worry about including too much detail- that's the kind of stuff most of us really enjoy). I like the roll cage, and the wiiide front cycle fenders give it a vicious looking stance.
What are you using for the braided oil line?
PHOTOBUCKET SUCKS
Old 11-27-2006, 12:49 AM
klutz_100's Avatar
Double "wow" with a pinch of "eek" topped of with a dash of "awsome" !
Personally, I love this kind of thread so pile it on!!!
Old 11-27-2006, 01:02 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
It come out fantastic, push me to start mine
gio
Old 11-27-2006, 09:49 AM
quadzero's Avatar
Excellent work on the fans. Also great idea with the pin-locator fixing elements. Sure makes construction and test fitting a lot easier.
Old 11-27-2006, 10:55 AM
klutz_100's Avatar
Oh Lord! Another WIP?!?!?!? LOFL
Old 11-27-2006, 11:48 AM
deltableh deltableh is offline
Send a message via ICQ to deltableh Send a message via AIM to deltableh Send a message via MSN to deltableh Send a message via Yahoo to deltableh Send a message via Skype™ to deltableh
This looks really good man. Wide tyres look a bit awkward from some angles, though.
Old 11-27-2006, 03:13 PM
Martin S's Avatar
Thanks all !
MPWR: The braided lines are made from what I believe is called solder wick or desoldering braid. The stuff you use to suck up molten solder when removing electrical components from circuit boards. Once bent into shape it can also be strengthened by brushing on CA-glue wich gets sucked in between the wires..
Latest progress:
Finished:
Old 11-27-2006, 10:46 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
looking GREAT. I love the form fitting radiator
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 12-02-2006, 06:06 PM
Martin S's Avatar
Small update.
I have finished the rollbar and made a set of silencers today. Made from aluminum and brass tubing. They will sit along the body side.
The oilcooler I started last time is also painted and more or less finished.
Latest progress:
Finished:
