Old 06-30-2003, 01:16 AM
Jimster's Avatar
Jimster Jimster is offline
Here for the pussy, man.
Send a message via ICQ to Jimster Send a message via AIM to Jimster Send a message via Yahoo to Jimster
Thats really how most primed bodies are- it should smooth out after the paint coat- Primer is a drier substance than a tamiya spray
Check out my Pride and joy in AF- and discuss your favourite Alfa Romeo
2007 Audi A4 3.0 TDI Le Mans
Old 07-06-2003, 06:23 AM
primera man's Avatar
"P-Man"
Just updated the first page about painting and added a few extra things to try and cut down on alot of the threads and PM's i get about stuff i left out. Not to much added but hopefully it maybe abit better.
Have another read and see if its improved now and helps out
View All My Models Here.
Old 07-06-2003, 09:38 AM
MR-2RaCeR's Avatar
MR-2RaCeR MR-2RaCeR is offline
Send a message via AIM to MR-2RaCeR
You dont actualy cook it, he means to let it dry in there because its the most dust f
hey choppinporkchop, wut he means is you need to sand out all the mold lines where it wuz stamped. They are mostly around the front and rear bumper.
Old 07-12-2003, 10:19 AM
jomz's Avatar
jomz jomz is offline
hmmm, just wondering if sanding is supposed to be done after primer-ing, meaning: sanding the primer-surface to a baby-smooth smoothness...
Old 07-16-2003, 06:17 PM
DJ RaYgU's Avatar
DJ RaYgU DJ RaYgU is offline
he means sand it before priming. But u can sand after u prime if u have any flaws on the surface of the primer.
Current Project:
Fujimi Veilside Combat Silvia S14...almost finished
Old 10-17-2003, 01:42 PM
Headlight's Avatar
Headlight Headlight is offline
Question Molding Lines
I am really dumb as I am very new to this and I don't understand with text explanations. Sorry... Please bare with me.
When you say that we must sand the Molding lines away, Could you maybe give a picture to show what these look like. I am not sure what you mean by this. Also, I am concerned about the Grit of the sandpapers you mentioned. The sandpapers here in South Africa are a little rough @ 600Grit. Im not sure whether your grit is the same as our grit??!? Please help
Regards
Headlight
Old 10-19-2003, 07:55 PM
hin2barry hin2barry is offline
Re: clearcoat
Can you explain to me how to exactly clearcoat a car since im a newcomer!!
email me at [email protected]
Thanks for your help!!
Old 11-07-2003, 04:39 AM
andreasgtr's Avatar
andreasgtr andreasgtr is offline
I have a little tecnique to avoid finger prints:
Use rubber gloves/ doctors gloves...very thin like a 2nd skin and no prints at all
My Gallery
Old 11-07-2003, 11:04 AM
Profoxcg Profoxcg is offline
Newbie - but thanks for the info !
Hi guys, / and girls if any...
I am new to building models; I am actually an rc guy (Mini-z). I want to paint autoscale bodies and build some models like you do.
I want to make sure I understand the proccess of painting a body, and please correct me if I am wrong.
1- sand body to eliminate error and fill in little gaps with putty and sans and make is nice an smooth. Work up to a 1200 grit SP. Q: do I sand it wet?
2- apply primer, (tamiya fine white) I apply coats to create a smooth surface for paint to grip on to. if there are inperfections in between coats I sand with 1200 grit SP? and repaint. wait a few hours between coats if I need to sand, otherwise apply coat evey 20 mins just to be save... apply enough coats to cover the body but not hide details.
3. let dry for a day or two.
4. begin color coat light a light mist, let it dry for a few minutes (20mins) then apply second coat. Once I start to build some color I let it sit for a day or two then I sand the paint with 1200 grit? to get rid of imperfections (orange peel if any) - Q: do I sand it wet? then wash? then paint final coats.
5. let dry for a week at least.
6. sand very lightly once gain to get rid of errors (as per another thread i read here) and ..
7. Use rubbing comppound to "cut" back the paint/clear coat... (is tamiya rubbing compound ok?)
8. apply clear coat.. let it dry <-- not always needed unless decals are applied... let it dry for a day or so.... (go back to seven and then to 9.)
9. Wax it with modeling wax.
10. enjoy your model
thanks for you help. I look forward to comments. My main concern in the sanding, wet or dry on paint and primer. and why does the finish coat needs to be slightly sanded?
thanks
Link to my refences:
http://www.automotiveforums.com/vbul...threadid=89313
Old 11-16-2003, 05:53 PM
DJ RaYgU's Avatar
Yo wut up guys. This is a kinda newbieish question given that im still kinda newbie: before you prime, do you sand the whole car or just the mold lines only? Thanks.
Old 11-16-2003, 06:28 PM
Re: Another......"HOW TO" prepare a body for primming and painting
Old 03-16-2004, 12:06 AM
carlisimo carlisimo is offline
Send a message via AIM to carlisimo
After some searching, I've realized I'm not going to find rubbing/polishing compound, nor sandpaper above 600 grit (best I find is those Testor's sanding films) around here. Do these have other names?
Old 03-30-2004, 06:52 AM
drunken monkey's Avatar
Razor Sharp Twit
this is going to sound like a really dumb question
but
what is a mist coat?
what is a wet coat?
Old 04-11-2004, 05:44 AM
sugarfree's Avatar
sugarfree sugarfree is offline
also has one 'sounds-silly' question. i've got this tamiya rubbing compound, and been using it pretty recently. the question is, do i press hard or just lightly scrub the body??? how do i get into those tiny or tight crevice (spelling??). so yea... anyone can help?
as for drunken monkey, this is my intepretation:
* mist coat -> a light coat, u spray it with quite a far distances like covered earlier in the topic.
* wet coat -> a more thicker coat that u applied on ur model. add a little bit more on this one, u'll get that runny paint job.
well, those are mine. corect me if im wrong.
life begin after 5,600rpm
BOOBAA rulez
Old 04-24-2004, 06:50 AM
Razor Sharp Twit
ok, another quick question.
if i'm going to be applying a clear coat finish, do i need to sand down any orange peel (major or minor) in the colour coat first?
AF's Guidelines
Read them.
Who has the link for the "how to" on replacing plugs and wires ZR800 Sebring | Sebring Coupe | Convertible 3 05-12-2006 12:01 PM
Body Dmage repair and Paint. Need Info Please !!! djstorman '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 11-04-2004 06:34 PM
"How to" make a spinning paint stand Renegade Car Modeling 12 05-09-2004 04:11 PM
81' zx for sale & 280zx seat swap "how to" JDan 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 0 01-12-2004 03:36 PM
Body Kit Install and Paint costs....? Icemaster Exterior | bodykits | Lighting 2 06-20-2003 07:33 PM
