#46
Re: 3800 Regal owners
I never have understood how they can claim it removes carbon buildup. You gotta wire wheel that crap off most of the time. 3 - 4 + mpg for me hopefully it stays that way!!
Troy |
#47
#48
Ok, today I got a DTC PO134 O2 sensor 1, bank 1 no activity. Anyone got the dianostic tree for the DTC or just a bad O2
Key on Engine off test: Pink & black wires 11.93volts Purple & Tan wires .38 volts Last edited by troy1; 02-09-2006 at 10:33 PM. |
#49
#50
Gee I wonder if this what was causing my crappy MPG
Crappy Borg O2 sensor from the get go?
#51
The pink is 02 sensor heater which should read around 12v. Black is ground. The purple wire is 02 sensor activity going back to the PCM. Voltage will vary from 1.0 v (rich) to .1 v (lean). The tan should be the PCM reference signal which is around .45 v. coming from the PCM. I recall the purple is where you tap into for 02 sensor activity for Autometer type scanner gauges. I'd bank on the Borg 02 sensor and replace it with an AC Delco AFS 109. Good luck!
#52
Put it on the snapon scanner and said low activity. The guy I talked to thinks the upper intake has a vaccum leak and it just leaned it out to much.
#53
#54
Well did the UIM gaskets this morning started at 9 done by 12:15. I did find some antifreeze back by the 4 & 6 injectors not a lot but some. Most likely it was from when I took the bolt out to get the EGR sheild off. It didnt look like the old gasket was sealing well. Might swap out the MAF with a known good one.
