Old 12-14-2004, 06:36 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: Eclipse=best subs in the world
Originally Posted by bumpinstang77
Say u got a SE 15 in 4 cubes tuned to 30 w/ 40 sqin of port area playin with 750watts. Put 2 se 15's in 8 cubes tuned to 30 w/ 80 sqin of port area and 1500 watts it will be approximately twice as loud to ur ears.
it will be 3dB louder, not twice as loud. Twice as loud to humans is anywhere between 6-10dB
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 12-14-2004, 06:38 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
I know u know what ur talkin about but look dude......double the cone area thats 3db double the power that's 3db and the doubling in size and port area will yield around 3 db thats 9 db damn near twice as loud to the human ear.
Old 12-14-2004, 07:23 PM
sr20de4evr's Avatar
You aren't doubling the size and port area though, you're keeping it the exact same per sub which is what matters.
As for the doubling of power, I'm really not sure what to think. Some say that adding a 2nd sub automatically yields 3dB, and doubling the power adds another 3dB (so 2 subs with 600rms each will be 6dB louder than 1 sub with 600rms), but some say that doubling the displacement to gain that first 3dB includes a doubling of power, because if you just double the subs and split the power between them, you aren't actually doubling the displacement, you're just splitting the same total displacement between 2 subs instead of 1 (say 5L of displacement total, in one case you have 1 sub displacing all 5L, and in the other case you have 2 subs, each displacing 2.5L, in the end it's still 5L). So doubling the subs and the power (so 2 subs with 600rms each vs 1 sub with 600rms) only gains you 3dB. I've heard arguments on both sides and I don't know which one to think. I guess I just need to do some testing to figure it out for myself.
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-14-2004, 08:32 PM
In my original post i said to double the box and port size...... double cone are=3 db w/ same power...that's why setups w/ a lotta subs don't need a lot power to get rediculously loud. Test but from my experiences doubling all that i said is twice as loud to my ears.
Old 12-14-2004, 08:51 PM
sr20de4evr's Avatar
yes, but going from 4cf with 1 sub to 8cf with 2 subs isn't doubling anything, sure it takes up twice as much space, but as far as the performance of each sub goes, it's the exact same. By what you said, if you had 2 boxes, each one was 4cf and tuned to 30 with 40sqin of port area and they were sitting next to each other, and then you knocked out that wall and joined them so they became 1 box, you would gain 3dB, but that's not the case. Doubling the volume of the box is necessary for running 2 subs, it's not something that increases output, it's just something you HAVE to do to run 2 subs in the first place, just like cutting a hole for the 2nd sub or adding more wires.
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-14-2004, 09:56 PM
snb778 snb778 is offline
Send a message via AIM to snb778
I think you would need 3,000 watts there (1500+1500) to be 3 times as loud.
Old 12-15-2004, 02:08 AM
You could put another sub in the same size but the response would be all fucked up but what i was sayin is basically doubling your substage will double the output. another sub double the power and double the original box space. The reason I know its twice as loud is because a lot of people I do installs for will start with one sub then upgrade to 2 and I do all this and it's about double the loudness.
