Old 10-27-2003, 12:44 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
any final thoughts on my car problems before i declare her dead for the winter?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 10-27-2003, 12:58 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Final Suggestion.... throw they stock 19lbs injectors and stock MAF. You car will idle fine with these... if it doesn't then fix that first... once that is done then go back to the 42lbs. But if it won't idle ok with 19lbs something besides injectors is wrong.
Edited: This was all the Great Mustang Mod Hi-Flows idea I stole from pages earlier.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 10-27-2003, 01:09 PM
yeah but the 19# injectors arent gonna supply enough fuel to keep it running?
Old 10-27-2003, 01:18 PM
GTStang's Avatar
Stang Guy
19 will give it plenty of fuel to idle and will only be lean way up in the RPM range. This is just to remove the issue of the #42 injectors as a problem and if there is another problem it will be easier to recognize with this set-up.
Old 10-27-2003, 01:25 PM
well ill give it a try as soon as theres a nice day again. cause its like 40 degrees in my garage these days. damn wisconsin weather!
Old 10-27-2003, 03:19 PM
GTStang's Avatar
Stang Guy
LOL I hear you it ain't much warmer here in Mass now. I just bought a woodstove to try to keep my garage warm in the winter.
Old 10-28-2003, 06:55 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Re: Now it wont even start
Originally Posted by HiFlow5 0
Would it be possible for you to put back in your stock 19 lb-hr injectors and stock MAF meter? Just bump your fuel pressure up to about 50 psi, and see if it runs then?
Humm, I guess it was over looked when I suggested it.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 10-28-2003, 01:46 PM
GTStang's Avatar
Stang Guy
No it wasn't overlooked by me. At the time I was trying to think of something to so without him having to do the pain in the ass work of swapping injectors. But I should have credited you oh great 1. Look above I have fixed my ways.
Old 10-29-2003, 12:46 AM
sorry HiFlow i did see your response before, but just like GTStang said i was really looking for ANYthing else to check before fucking with changing out the injectors. thanks though bro , but i put her to sleep for the winter.
Old 10-29-2003, 03:33 AM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
sounds romantic - a little snow outside, a little woodstove near the front fender, an open hood, grease everywhere, fleetwood mac smoothly playing over the radio - some warm brie, a wool sweater and the gtstang's legendary Mustang.
eh - give me jessica simpson anyday.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 10-29-2003, 07:14 AM
HiFlow5 0's Avatar
Stanger
Hell yeah!!! I'd take that dumb blonde anyday! She's F'ing hot!!!!!!!
-2013 Ford Flex
-1999 Ford F150
Old 10-29-2003, 06:23 PM
GTStang's Avatar
Stang Guy
Hell yea she is hot.... Ya know every1 bitches that she is dumb as shit now that, that show Newlyweds is out.... But I gotta be honest I like it better that she is retarded
Old 10-29-2003, 06:38 PM
One Last Thought! So keep the hormones down, lol!
When I hooked up my aftermarket auto meter gauges I removed the stock senders to replace them with the autometer ones right. Now being that these are different senders than stock i assumed they wouldnt work with the stock gauges properly so I left the stock wires off. Do you think that effected my stock computer in any way since it couldnt read coolant temperature or oil pressure? Would that effect running conditions, such as lopey idle or a "rich condition"!!? Doesnt the computer use ECT in its fuel table? Any thoughts?
Old 10-31-2003, 06:50 AM
GTStang's Avatar
Stang Guy
I can't remember which guages you did but I know the ECU does use the coolant sensor in it's calculations. So not having it hooked up could cause issue but I don't think it will at idle. But I'd hook it back up anyway
Old 09-10-2007, 08:10 PM
carbites carbites is offline
Did you check the terminals at the fuel injector connector and especially the terminal ends for a soild connection on the fuel injector pin itself.
Motor swap and now my car wont even go past 25mph 1992 honda monster '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 07-29-2010 12:01 AM
Originally a Radiator Fan Problem, Now Car Won't Start fiskee '91 - '96 2 09-09-2009 12:17 PM
95 4runner suddleny wont even start! revenantsoul 4Runner/GX470 2 09-15-2007 12:37 PM
1988 305 -350 major problems wont even start!!!! aaron600rr C/K 16 06-04-2007 12:11 AM
It kept stalling now its not even starting. ArthurNY Camaro Discussions 6 03-29-2006 12:23 PM
