Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 07-25-2007, 11:26 PM
AUTOSALESCOSTARICA AUTOSALESCOSTARICA is offline
Re: Program keyless remote-Need instructions
Hi, can anyone tell me how to program a keyless entry remote for a corolla 1998? thanks
Old 07-26-2007, 09:10 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Read the previous posts in this thread. Particularly post #41
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-14-2007, 05:29 PM
dcbus dcbus is offline
I have a 2002 Rav4, purchased 2 remotes from ebay, and attempted to program the remotes with the below instructions but step #10 didn't happen... Any ideas?
Do I have to do the "confirmation" or "prohibition" step in #8? What do those mean?
1. Driver door open and unlocked. Key out of the ignition
2. Insert the key and remove 2 times in 5 sec.
3. Close and open driver door 2 times in 40 sec.
4. Insert the key and remove it again from ignition.
5. Close and open driver door 2 times in 40 sec.
6. Insert the key in ignition,
7. Close the door,
8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”)
9. Remove the key
10. Power lock will cycle to confirm
11. For add or rewrite mode within 40 sec of the confirmation,
A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds.
B. within 3 sec press “Lock” button for more than 1 sec and release.
C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice.
Old 09-06-2007, 08:20 PM
sanek sanek is offline
Originally Posted by daffy_duck-010
The dealer was happy to give it to me so here is the procedure. let me know if it works. (Camry 02 and 03)
7. Close the door,
9. Remove the key
4Runner Instructions
I have a 1999 4Runner and I followed the directions above (which I've copied below) with one exception. In step 8 -- I held the lock button instead of the unlock button in order for the directions to work.
Step 1 - open drivers side door and get in your vehicle.
Step 2 - put key completely into ignition,then pull out.
Step 3- with door open, lock and unlock 5 times on door console (ten clicks total).
Step 4 - close door then open door.
Step 5 - lock and unlock 5 times on door console (ten clicks total).
Step 6 - put key completely into ignition then turn to the on position then pull key out (you will now hear the door locks lock then unlock a couple of times)
Step 7 - now quickly press the lock and unlock buttons at the same time only for about a second.
Step 8 - then quickly press the lock button for just a second.
Step 9 - exit car and close the door
After you do this you should hear a beep then your lights will flash. This will indicate that your remote is programmed to your vehicle.
i tried this procedure to program 2000 4runner and it wouldnt work, and when i press lock and unlock ten times it keeps locking weaker and weaker. do you know if your instructions work for my car thanx
Old 09-21-2007, 05:45 PM
luivarca luivarca is offline
hi. i have a corolla LE 98, i just bought the keyless entry remote. does anyone knows how to program it? thanks
Old 09-28-2007, 08:54 AM
Tamarina Tamarina is offline
Hi Everybody..I have a 1995 Toyota Corolla. I just broke the keyless remote and now bought a new one. The new one does not have the programming instructions with it.
Dealer is asking for $96 to program it. Can someone help me with the programming instructions?
Details - Part# 08191-00860
FCC # BAB237131-013. Thanks!! Tammy
Old 09-30-2007, 12:41 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
The instructions for the BAB237131-013 remotes are the same used for the RS3000 system with BAB237131-022 remotes.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 09-30-2007, 12:22 PM
Hi OnBlsht..do you have instructions for it?
Old 10-02-2007, 09:51 AM
netsfan549 netsfan549 is offline
question... My car came with Toyota Alarm but i lost remote can this alarm remote work? thanks
http://www.keylessremotesforless.com...4T_4B_Hold.jpg
Old 10-02-2007, 03:29 PM
Onblsht's Avatar
Authorized Vendor
No, the GQ43VT14T remote was never used on a 4Runner.
Old 10-03-2007, 01:56 PM
-stev=o -stev=o is offline
I ran into this problem. My issue was that the door closed/open sensor was busted because at some point, my metal seatbelt latch got caught between the door, and the frame/sensor, and I closed the door (thus smashing the sensor behind the rubber housing on the door frame). I got around it by snagging the working sensor out of the passenger side.
Old 10-16-2007, 08:12 PM
effe0525 effe0525 is offline
2002 Corolla
Hi, my 2002 Corolla uses the BAB237131-022 remote, I picked up a replacement on Ebay (matching model #) and need programming help. Any assistance would be appreciated. Thanks in advance.
Old 11-17-2007, 01:09 AM
To Program A Rs3000 Toyota Alarm For Corolla 98-00.
1 - Put The The Key In The Ignition "on" Position With Only The Driver's Door Open.
2 - Reach The Rs3000 Module Under The Driver's Seat.
3 - Press And Hold For 5 Seconds The Little Green Button On Left Side Of The Module (side Door), Until The Alarm's Led Stay Without Flashing.
4 - Press Any Button On The Remote For 1 Sec.
5 - When You Hear The Beep And See The Lights Flashing, Take The Key Out Of The Ignition.
6 - Enjoy Your Alarm.
Please Feel Free To Ask Any Question.
Also Have Keyless Instalation 4 Elantra And Mitsubishi.
Good Luck!!!!!!
The Following User Says Thank You to luivarca For This Useful Post:
hsnow73 (02-13-2011)
  #59
Old 04-16-2008, 12:55 PM
tinamarie1014 tinamarie1014 is offline
Originally Posted by Brian R.
Here's a confirmatory link for daffy_duck-010's post:
http://www.geocities.com/toyota_spee...ess_entry.html
thanks so much for all your info...i have a 2001 solara that i bought used and it only came with one remote and my dad does security at a car dealership and the owner gave me a second remote that matched exactly...the only thing wrong was the batteries were dead but then it worked as good as new...
Old 05-12-2008, 08:21 AM
xavier1117 xavier1117 is offline
how would i go about reprogramming a keyless remote for a 98 dodge intrepid?
Program 2007 camry keyless remote marty.graw Camry/Camry Hybrid/Vista 1 03-31-2010 08:13 AM
Dealer says new computer needed to program keyless remote, I think they are wrong.. hoover101 Sequoia 2 03-16-2010 11:17 PM
96 Camry CSI Program Keyless Remote JeanC Camry/Camry Hybrid/Vista 1 07-15-2009 12:28 PM
