Old 05-07-2014, 07:17 AM   #46
gtziaf
gtziaf's Avatar
Re: Ferrari 312PB 1972 Nurburgring - MFH 1/24
After so much time I manage to publish an update from my PB.
Meanwhile I worked on this Lotti for a Senna tribute...
So back to 312PB and her chassis... First of all I cancel the screws for the front part of the chassis (not realistic) and I made the tube frame, from some rods.
I decide to paint the chassis, because the Hiro's part is very rough for my taste. So after many days of sanding , I painted it with a mix of polished aluminum and white aluminum.
Then, I make the rubber upper part from a cut black cable.
Some wash follows...
After that, I saw some photos from the cockpit area (you can see also the tube frame). Here the pedals are four - +footrest - (not three Mr Hiro ) and the area are more complicated than in Hiro's kit. So I made it from scratch. Not 100% accurate but an improvement, isn't it...
Finally, I glued he tube frame in the chassis.
Not something really interesting or extreme, but after some time I manage to back to work.
Hope you like it and wait for your comments...
Best Regards
George
Visit our Greek Modelling Forum :
http://scalewheels-gr.com/
gtziaf is offline   Reply With Quote
Old 05-07-2014, 02:54 PM   #47
ianc911
Beautiful. Superb. Fantastic!
ianc
ianc911 is offline   Reply With Quote
Old 05-08-2014, 11:00 AM   #48
gtziaf
gtziaf's Avatar
thank you ianc...
Old 05-10-2014, 12:40 PM   #49
gastone
gastone's Avatar
Excellent work as always George!
gastone is offline   Reply With Quote
Old 05-13-2014, 11:44 AM   #50
gtziaf
gtziaf's Avatar
Thank you my friend...
Old 05-13-2014, 12:49 PM   #51
lovegt40
ItaloSvensk
lovegt40's Avatar
absolutely wonderful Lotus George. great great one!
Paolo - LoveGT40 Modelworks
website www.alsoldatino.com
my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber
FB: https://www.facebook.com/alsoldatino
lovegt40 is offline   Reply With Quote
Old 05-16-2014, 07:37 AM   #52
gtziaf
gtziaf's Avatar
Thank you Paolo!
Back to 312's progress with front suspension system.
But before that, I try to correct the Hiro's faults. So for the rear brakes hiro gave some PE parts. For the fronts, is only white metal. So I try to found some new PE's, to match the shines of the front and rears. Of course some modifications needed.
Also, I replace the front brake cooling hoses, and I add some details on it. I plan to leave the finished model without wheels and body panels, so I put the hoses in a 'freestyle' place.
The front suspension installed on the frame...
I add, PE rivets in suspension support points, as I do for rear parts.
So the front finished suspension is like this:
Hope you like it...
Best regards
George
Old 05-26-2014, 03:48 PM   #53
gtziaf
gtziaf's Avatar
Some interior progress, on my PB...
First of all, I prepare the fire extinguisher (not included in kit ) with some hi - tech bases
The preparation of electronic boxes follows...
Then, I paint the scratch-build pedals...,
and the brake fluid bottles.
Finlay, I prepare the wires for electronic devices.
So, at this time, the interior looks like this :
Hope you like the progress.
More interior work follows, before I stopped it for my Le Mans build...
Best Regards
George
Old 05-26-2014, 04:31 PM   #54
Lee Yoder
Lee Yoder's Avatar
Very nicely done! Also the Lotus is fantastic!
Later,
Lee
Lee Yoder is offline   Reply With Quote
Old 05-26-2014, 05:38 PM   #55
Sand03
Sand03's Avatar
Very nice detailed work!
Sand03 is offline   Reply With Quote
Old 05-27-2014, 05:06 PM   #56
ianc911
Looks really beautful!
The one thing I'd like to see is a blacker wash treatment given to the space between the two halves of the ventilated rotors. Seems like that area in the middle would be quite dark.
Keep up the fabulous work!
ianc
Old 05-30-2014, 03:26 PM   #57
gtziaf
gtziaf's Avatar
Thank you guys...
Ianc, thank you for your suggestion. I 'll improve it...
More follow very soon...
Old 05-30-2014, 11:09 PM   #58
Shunter
Shunter's Avatar
Loving your work, a beatuiful job on a very cool car.
Cheers
Shayne
http://motorsportmodeller.blogspot.com.au/
Shunter is offline   Reply With Quote
Old 05-31-2014, 03:03 AM   #59
gtziaf
gtziaf's Avatar
Thank you, Shayne!!!
Old 05-31-2014, 01:06 PM   #60
Lee Yoder
Lee Yoder's Avatar
Is that a horn mounted to the front bulkhead?
Later,
Lee
